Reorganize categories?
Hello!
I try to move the Content to a other HDD and it dosn´t work. I delete all and try a new installation and I have a problem:
- In the products folder I see the content vom 0 -> Z and I can install the products.
- In the Categories folder I see the folder but every folder is emty.
- If I use the search function there ist no result.
What can I do?
Regards
514 x 892 - 38K
506 x 987 - 41K
How did you install - with Install Manager or within Daz Studio? Can you see the content under Daz Studio Formats, selecting the content diectory you installed to (Daz Connect if you installed within DS)?
I use Daz Studio with Connect.
Try to install Infogal and ToonCow. I found the products in "I" and "T" but not in the categories.
It doesn't lok as Infor Gal has proper categorisation - there are no content type tags at top-right of the thumbnail - but toon Cow looks OK. If you right-click you should have Show Asset In options, see what they give you.
OK. Thanke you
