Environment Tint Problem!
in New Users
HI all. I am using https://www.daz3d.com/play-video-games environment and outside the window in my renders, everything has a green tint to it. I have tried more than one background in the environments tab both .hdr and .jpg. I have had this problem before and i dont recall ever finding a prper solution, I think I just started a whole new project last time but I would like to know what is going on. In the photo the sky should not be that color, I use that background all the time. Using iRay 4.10. Mac. Any ideas?? Many thanks!
Hi is this Iray or 3Delight? Is the color effect possibly something to do with your glass window? Try a test and go to surfaces, select your glass panes and under opacity make it 0% to remove the glass and try a render to see if it is the glass affecting the tint you see outside the window. Also, did you look at the tone mapping?
Make sure under the Environment Settings that Visualize Finite Dome is off if using Iray.
It is not the window bc I did a render with no wall and it was still like that. I also changed the glass on the window from default to the Iray Glass. What about the tone mapping?? TY.
Wont that turn the exterior to alpha blocks? I would like to have the image in the back and it normally works fine. What variable has really changed to make it green tinted?? TY for your help!
Ok that worked thank you so much.
