Environment Tint Problem!
HI all. I am using https://www.daz3d.com/play-video-games environment and outside the window in my renders, everything has a green tint to it. I have tried more than one background in the environments tab both .hdr and .jpg. I have had this problem before and i dont recall ever finding a prper solution, I think I just started a whole new project last time but I would like to know what is going on. In the photo the sky should not be that color, I use that background all the time. Using iRay 4.10. Mac. Any ideas?? Many thanks!
  • CGHipsterCGHipster Posts: 241
    Hi is this Iray or 3Delight?  Is the color effect possibly something to do with your glass window?  Try a test and go to surfaces, select your glass panes and under opacity make it 0% to remove the glass and try a render to see if it is the glass affecting the tint you see outside the window.  Also, did you look at the tone mapping?
  • FishtalesFishtales Posts: 6,238
    Make sure under the Environment Settings that Visualize Finite Dome is off if using Iray.
  • It is not the window bc I did a render with no wall and it was still like that. I also changed the glass on the window from default to the Iray Glass. What about the tone mapping?? TY.
  • Wont that turn the exterior to alpha blocks? I would like to have the image in the back and it normally works fine. What variable has really changed to make it green tinted?? TY for your help!
    Vanishot said:
  • Ok that worked thank you so much.
