unable to use Reality in Daz 4.11 beta
hi all
I use Reality.... when I copied the plugin into Daz 4.11 beta I got the PostgreSQL Connection Error and when I removed the plugin the error went away.
anyone else encounter this?
hi all
Hopefully it will work when it becomes a full version. I am not sure about the beta but I do not have the beta installed right now. I can try it later.
I encountered the same issue when I finally got around to updating to Daz 4.1. Ultimately, I had to upgrade my version of Reality as well. My assumption would be that once 4.11 is out of beta, Paolo will release an update to Reality to ensure compatability. Of course, you could try doing a complete uninstall/reinstall of Reality, just in case, but my guess would be that you'll have to wait for an update.
Cheers
I also use reality and did not encounter that. When you say you copied the plugin, are you being literal? I am pretty sure I did a standard install of reality into the beta (I also have 4.10 with reality installed).
How did you copy the Reality Plugin, for instance did you copy the whole folder or just the plugin file as I just tested it and it works fine
DS 4.11.0.196 Pro (64bit) Public Beta, Reality Plugin 4.3.1.16203
