SOLVED Tara 2 stopped working
HeraHera Posts: 1,960
Hello!
I'm trying to use Tara2 for G8F https://www.daz3d.com/tara-2-hd-for-victoria-7-victoria-8 and it used to work fine earlier. And she has a magnificent set of horns and wings and such to create an awesome deamon with. Only that it has stopped working. When I try to load her horns - they won't load, and I get this message below. (The first messages is after loading Tara 2 successfully, the second is when I try to load a set of horns.
What can be wrong, I've no idea what the log file might say.
This is the error message I get when I  try yo load her horns: I get the same kind of error regardless of what horns or other attachments I try
2018-08-21 20:52:16.964 Loaded file: Tara 2 Victoria 8.duf
2018-08-21 20:52:17.966 Loaded image Tara2LegsMapD_1003.jpg
2018-08-21 20:52:18.092 Loaded image Tara2EyeMapD01_1007.jpg
2018-08-21 20:52:18.508 Loaded image Tara2ArmsMapD_1004.jpg
2018-08-21 20:52:18.660 Loaded image Tara2MouthMapD_1005.jpg
2018-08-21 20:52:19.097 Loaded image Tara2FaceMapD_1001.jpg
2018-08-21 20:52:19.577 Loaded image Tara2FaceMapD01_1001.jpg
2018-08-21 20:52:19.980 Loaded image Tara2TorsoMapD_1002.jpg
2018-08-21 20:52:20.136 Loaded image Tara2EyelashesMapT01_1006.jpg
2018-08-21 20:53:24.233 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePath: Unable to connect to the database, can not quote
2018-08-21 20:53:26.715 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in productGet: Unable to connect to the database, can not quote
2018-08-21 20:53:26.960 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.961 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.962 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.963 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.965 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.966 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.969 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.981 File loaded in 0 min 0.0 sec.
2018-08-21 20:53:26.981 Loaded file: Tara 00 HornsD.duf
Post edited by Hera on
  • Looks like a database issue. How did you install Tara 2, DIM or Connect?
  • HeraHera Posts: 1,960
    DIM the first time, some months back.
    Then I redid an installation today, to see if it fixed the problem I've been having. It did not. This time I did a manual installation, that is - I downloaded the zip, opened it and then dropped the content into the DAZ directory, overwriting the old stuff.
  • You might try uninstaling and reinstalling, via DIM, to see if that fixes the database issue (if that's what it is).
    After re-downloading Tara I eventually noted that the horns WERE in fact working, but that they were moved to another folder. I deleted the old ones and kept the new ones. Ta-da :-)
