SOLVED Tara 2 stopped working
Hera
Hello!
I'm trying to use Tara2 for G8F https://www.daz3d.com/tara-2-hd-for-victoria-7-victoria-8 and it used to work fine earlier. And she has a magnificent set of horns and wings and such to create an awesome deamon with. Only that it has stopped working. When I try to load her horns - they won't load, and I get this message below. (The first messages is after loading Tara 2 successfully, the second is when I try to load a set of horns.
What can be wrong, I've no idea what the log file might say.
This is the error message I get when I try yo load her horns: I get the same kind of error regardless of what horns or other attachments I try
2018-08-21 20:52:16.964 Loaded file: Tara 2 Victoria 8.duf
2018-08-21 20:52:17.966 Loaded image Tara2LegsMapD_1003.jpg
2018-08-21 20:52:18.092 Loaded image Tara2EyeMapD01_1007.jpg
2018-08-21 20:52:18.508 Loaded image Tara2ArmsMapD_1004.jpg
2018-08-21 20:52:18.660 Loaded image Tara2MouthMapD_1005.jpg
2018-08-21 20:52:19.097 Loaded image Tara2FaceMapD_1001.jpg
2018-08-21 20:52:19.577 Loaded image Tara2FaceMapD01_1001.jpg
2018-08-21 20:52:19.980 Loaded image Tara2TorsoMapD_1002.jpg
2018-08-21 20:52:20.136 Loaded image Tara2EyelashesMapT01_1006.jpg
2018-08-21 20:53:24.233 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePath: Unable to connect to the database, can not quote
2018-08-21 20:53:26.715 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in productGet: Unable to connect to the database, can not quote
2018-08-21 20:53:26.960 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.961 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.962 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.963 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.965 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.966 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.969 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
2018-08-21 20:53:26.981 File loaded in 0 min 0.0 sec.
2018-08-21 20:53:26.981 Loaded file: Tara 00 HornsD.duf
Looks like a database issue. How did you install Tara 2, DIM or Connect?
DIM the first time, some months back.
Then I redid an installation today, to see if it fixed the problem I've been having. It did not. This time I did a manual installation, that is - I downloaded the zip, opened it and then dropped the content into the DAZ directory, overwriting the old stuff.
You might try uninstaling and reinstalling, via DIM, to see if that fixes the database issue (if that's what it is).
After re-downloading Tara I eventually noted that the horns WERE in fact working, but that they were moved to another folder. I deleted the old ones and kept the new ones. Ta-da :-)
