How to remove textures from figure
davesodaveso Posts: 7,942
I have G3 With Skin Builder 3. Then I added brows with Supernatural Brows. Also use Anagenesis on it.
How can I remove all that stuff and just get back to straing, even white figure without any skin texture. This applies even to G3 or 8 when you load them they come pre-textured.
  • TSasha SmithTSasha Smith Posts: 27,432
    I have been trying to figure this out too.  I also want all shaders removed too.  Reset to a null setting.
  • Oso3DOso3D Posts: 15,098
    Create a cube.
    convert it to Iray.
    save as shader preset ‘Blank’ or something.
    apply shader to whatever you want to blank out.
    Oso3D said:
    Create a cube.
    convert it to Iray.
    Why a cube?  How do I convert it to iray?
  • nicsttnicstt Posts: 11,715
    edited August 2018
    Got to surfaces tab.
    select the whole figure (or part to check out my explanation)
    In the image:
    1 - Multiple (well, at least two different) Images loaded into that slot.
    2 - No Images present in this slot.
    3 - The same image loaded in all slot instances (five surfaces selected).
    The number in brackets (5) repeated multiple times, indicates how many surfaces are selected.
    253 x 1132 - 60K
    Post edited by nicstt on
  • scorpioscorpio Posts: 8,533
    You can't remove shaders the DS default shader is a shader - even without texture maps it still will have a shader.
    Oso3D said:
    Create a cube.
    convert it to Iray.
    It doesn't have to be a cube could be a sphere or plane or anything. You convert to Iray by applying the Iray Uber Surface Shader.
  • nonesuch00nonesuch00 Posts: 18,830
    For G8
    1) Open the G8 Dev character
    2) Save the materials as a material preset
    3) Apply saved material preset to the G8 character
    4) I think, but don't remember, that you can apply the material preset you just saved to G3 character too
