Kyoko Hair Replacement
WSC
This is a really old hair figure that I really like but could use an updated version. Does anyone know of something similar for G3-G8?
WSC
Subscribing would love to know too
I would highly recommend Katharina Hair by OOT
https://www.daz3d.com/katharina-hair
YOu would need to manually fit it to G8F but that is little issue. Jus parent it to the head of G8F and you're done . If the figure is NOT standing in the default position, still parent and then zero the XYZ trans and Rotation for the hair.
Thanks fo the recomendation. I'll take a look at it. I tried to use OOTs Anne Hair, but it comes out to thin and transparant.
Can you move the hair (left side) out of the way with Katharine hair? So it doesnt fall over the eyes too much?
I don't think it's going to quite deliver the look I'm looking for which is a side part with the hair brushed over.
Yes, the hair has lots of movement.
This is my own artwork showing the hair in use:
https://www.deviantart.com/mattymanx/art/Hanna-4-Closeup-673887941
https://www.deviantart.com/mattymanx/art/Hanna-4-673663100
https://www.deviantart.com/mattymanx/art/Angelic-Beauty-4-Closeup-664299616
https://www.deviantart.com/mattymanx/art/The-Posse-2-659978760 - Used 3 times here. The two girls middle left and the girl on the right too
https://www.deviantart.com/mattymanx/art/First-Mate2-647580919
https://www.deviantart.com/mattymanx/art/Illuminated-Beauty-3-640551896
https://www.deviantart.com/mattymanx/art/Hanna-633278948
https://www.deviantart.com/mattymanx/art/Sheer-Elegance4-635045141
https://www.deviantart.com/mattymanx/art/Hanna2-633790661
Hope that helps.
You could also take a look at Shanni Hair (available at Renderosity). I've used that a lot lately and really like the options it has for morphs and control.
Thanks for showing!
I think may not longer be available. Searched for it, but does not seem to be there.
You did, in an idirect way. I took another look at the hair I had from oot. Originally, it render terribly, but by tweaking the transmap, i'm getting beter results and might be able to use it till I find something closer to the Kyoko Hair.
Thanks!
I added an 'h' .. the full name is "Sanni Hair for Genesis 3 and 8 Females"
Still not the same (no assymetrical comb over) , but maybe a bit closer...
https://www.daz3d.com/ajax-hair-for-genesis-3-female-s
This would be a nice update for another older V4 hair I'm using....
A little too wavey as the look I'm going for is more straight hair with the comb over. Nice thought. Kind of a Superhero look....
A lot of older hair is more realistic in terms of proportion, while looking a lot less realistic otherwise. Comes from the geometry, I guess, which is now built from tons of strips. One side effect of this seems to be much more bouffant hair - if you want kinda plain, straight, glossy type hair that renders as nicely as newer hair, you're kind of out of luck.
Agree. That's exaclty the kind of hair I'm looking for. Impossible to find.
https://www.daz3d.com/raffaella-hair-for-genesis-3-female-s
Getting closer I feel. Lovely hair in any case. This one has that comb over you were looking for.
Nice. I have one like it one watch. Waiting to go on sale .If it were straight, it would be perfect.
