Crashing when trying to check on render?
no nose
Ive had this happen sometimes the past few days, I'm not to sure what i'm doing wrong here. What happens is that i'll leave DAZ rendering in the background, then sometimes when I decide to check on the render the whole application crashes, not even giving a "woops there was a crash" pop up.
well it's the only log file I found, it's better then nothing
Take a copy of the log file just after DS has crashed - any relevant messages will then be at the end.
That said, searching for "starting" finds the start of each session and looking back from there one can see if there's an exited line - if not, DS presumably crashed in some form. One of the crashes appears to have happened after saving the finished render to the temp folder, one is after generating the scene graph, and the other doesn't appear to be after render-related messags at all so the result isn't terribly informative (and of course we don't know if there were messages that were never written to the log). Are you getting crashes in other circumstances too?
ok, I'm guessing this is all the parts of the log that matter. So far I haven't had any crashes from other reasons
Does that have any more information than the last? I see only the same abnormal terminations.
Haven't had any crashes since, I'll try to see if it happens again tommorow since it's super late.
