Big Girl Morphs for Genesis 8 Female clothing smoothers
barbultbarbult Posts: 26,607
Big Girl Morphs for Genesis 8 Female by SickleYield and KindredArts contains BGM Heavy Clothing Smoother morph and BGM Heavy Clothing Smoother Skirts morph, but I can't figure out how to use them or what they do. I believe these are projection morphs that should affect the clothing and not the figure, but I don't see any change in the clothing when they are dialed in. The renders are identical, whether they are dialed at 0% or 112%.
What are these morphs supposed to do and how should I use them in a normal workflow?
  • barbultbarbult Posts: 26,607
    Aha! I was using DS 4.11.0.171. These morphs do nothing that I can see in that new beta version. In DS 4.10.0.123 I can see them move the clothing, although I still could use some help in figuring out how to make the clothing smoother. It seemed to make the skirt looser and lumpier when I dialed the skirt smoother a little bit.
    It does make the skirt a bit looser and un-cups it from the belly and crotch.  To truly smooth, as in remove all visual irregularites you're going to need to use the modifier.
    Thanks for your reply, SickleYield. Are you aware of any known issues with this product in 4.11.0.171? I submitted a help request about the fact that projection morphs don't seem to work in the beta version of DS.
    I've had trouble too, but I don't have a fix yet.
    Thanks. I figured it was a bug in the beta rather than something specific to your product.
