quickly catalog your piles of obj files with this script NEW PRO Version
mCasualmCasual Posts: 4,607
edited August 2018 in Freebies
https://sites.google.com/site/mcasualsdazscripts9/mcjmakemeaniceobjcatalog
and NEW !The PRO Version !
the PRO version can recursively descend in sub-folders ( a'.k.a. the wavefront abyss , scary i know but you're brave enough )
https://sites.google.com/site/mcasualsdazscripts9/mcjmakemeaniceobjcatalogpro
A script that loads one after the other a series of obj files
frames them in the camera frame
exports a viewport capture of each one as an image ( .jpg or .png )
each image file has the same basename as the .obj file
then optionally creates an HTML web page that displays those images and their name
Post edited by mCasual on
  • PraxisPraxis Posts: 278
    Yet another great script from you - Many Thanks!
  • IvyIvy Posts: 7,165
    Great script  Jacques . Thank you very much
  • mCasualmCasual Posts: 4,607
    edited September 2018
    Inventorize your tons of OBJ Files The PRO Version of the free script
    1080 x 1180 - 184K
    Post edited by Chohole on
  • mininessiemininessie Posts: 324
    thank you!
    UPDATE UPDATE UPDATE UPDATE UPDATE
    mcjmakemeaniceobjcatalog had a minor fix ( the HTML file was not completed/closed until you exited the script )
    and
    mcjmakemeaniceobjcatalogPro had a crucial fix without which the script didnt start ,
    the part of the script that fills the on-screen file list was checking the state of a check-box before it was created
    i found during a hours long search for the ladder Amy-the-librarian is stepping on
    1920 x 1080 - 467K
  • mindsongmindsong Posts: 1,772
    Grabbed the update, thanks!
    --ms
    Eta: great ladder...
    Post edited by mindsong on
  • Nice thank you very much
  • hphoenixhphoenix Posts: 1,335
    The only thing that would make this more awesome is if it could use imagemagick or some other method to put the path (in the content library) TO said object (if it's in there) and/or the File path to the object, as text ON the image.
    I was thinking you could put them in a directory, and then using the Directory manager, set this as an "Other" library and then it shows up...?
  • GreymomGreymom Posts: 1,147
    WOW - this is awsome!  Many thanks!
    My directories of unsorted .OBJ files are so large that I fear to go in there...it is dark, and there may be crawly things, and maybe I might not find my way out again.
    not today but soon i'll probably add an option to generate a CR2 or PP2  files per .obj,
    1 object plus the materials
    mmmmaybe 1 prop element per group
    in other news
    today or tomorrow i'm adding this 1940 chevy master deluxe special
    1280 x 720 - 104K
