Gilikshe renders: playing with shaders
24
  • AlbiejeeAlbiejee Posts: 153
    I really like where this-- toon with transparancies is going. :)
    gilikshe said:
    Still WIP
  • almahiedraalmahiedra Posts: 1,374
    edited May 2013
    Consider that It is only one layer and base not so complex as previous photoshop experiments. Here all is done with DS shader and UE2 lighting. This is screen layer.
    543 x 860 - 154K
    543 x 860 - 176K
    543 x 860 - 170K
    Post edited by almahiedra on
    edited May 2013
    Another. Shader output. One layer + plane base, Strong/Hard light. UE2.
    543 x 860 - 175K
    I need a little ingredient from UE2 light, its parameter __category, if it there is. I can't find it. Meanwhile I play with some other things, in this case expressions. It is a coarse output, with compose and change in opacity the shadow effect should be more subtle.
    500 x 500 - 120K
    500 x 500 - 123K
    500 x 500 - 127K
    500 x 500 - 120K
    755 x 1200 - 361K
  • TheNathanParableTheNathanParable Posts: 1,089
    That looks really interesting Gilikshe. Kinda reminds me of Street Fighter IV characters, who tend to have a LOT of muscle definition painted into their skin textures.
    Would you mind posting the values you used to get that effect? I'd like to know if a similar thing is possible with Visual Style's ambient occlusion settings.
    Give me this week to return to work with this and remmember what I did, It is RSL oclussion function with a step function. Just today the summer holidays begin, but I have still pending homework to correct.
    Sorry for delay. In oclussion I used:
    bias: 5E-05 (very,very small)
    samples: 64
    MaxDist: 5
    I use RSL shader builder oclusion function, I suposse is the same in shadermixer. I hope that you find it useful.
    New WIP. Shader with plain colors composed with four-step shadows, each color is in a different layer, layer images was from http://www.patterncooler.com/?tag=flower. Outlines around hearts was and error when I grouped layers, now I work in a version switchs on/off this inner outlines. Ramp in hearts is part of layer images, however I will set ramp functions. Step shadows have adjustable noise.
    1002 x 1670 - 503K
  • Joe.CotterJoe.Cotter Posts: 3,362
    Interesting :)
    Thanks Gedd.
    It appears that forum post need have a certain length, in another way post is not submited.
  • Jim_1831252Jim_1831252 Posts: 728
    Very interesting thread. I'm yet to play with shader mixer or builder, but it seems they are powerful tools.
    Thanks jimzombie.
    Yes, they are powerful. Builder more even, you can code your own block from very basic functions. Interfase is hard but you can know what is wrong most of time when you get errors.
    Another WIP, less WIP than another, but much work yet
    800 x 800 - 777K
    800 x 800 - 834K
    With outlines
    800 x 800 - 828K
    I like the last one with outlines. They help make the various parts of the image stand out :)
    Yes, outline offer more definition. But it was tedious apply it by geometry shell. Just now I finished to set the outline into shader and I am testing with extremely simple and fast renders like following. Face look exaggerated for now.
    600 x 600 - 95K
    800 x 800 - 166K
  • Eustace ScrubbEustace Scrubb Posts: 2,736
    So all of this is Shader Builder work?
    All is totally shader builder.
    Of course, spots in dragon and clothes and designs in egg use images layered, they aren't procedural, but layering is made in shader builder like outline, color, use of light etc.
    edited September 2013
    eyelashes is hitomi material, cornea is from chibigirl, rest is shader
    1000 x 951 - 2M
    1000 x 1000 - 2M
    1000 x 1000 - 2M
    Testing expressions
    200 x 200 - 78K
    200 x 200 - 74K
    200 x 200 - 74K
    200 x 200 - 79K
    200 x 200 - 77K
    Opacity added
    800 x 800 - 1M
    800 x 800 - 1M
    More Hair
    800 x 800 - 1M
    500 x 500 - 504K
    500 x 500 - 515K
    edited October 2013
    Ok. I'm playing a little with this to check how it works. There are 42 parameters, some for little tweaks, some for principal changes...and it is even in development...so...
    400 x 1000 - 329K
    387 x 1000 - 300K
    400 x 1000 - 328K
    edited October 2013
    An old WIP remaked. Old shader, next, current shader.
    Edit: Background is cyclorama with camera DOF.
    1200 x 1200 - 2M
    711 x 885 - 826K
  • scorpioscorpio Posts: 8,533
    This looks very interesting.
    Thanks scorpio64dragon.
    edited October 2013
    Fast experiment. Adding color light intensity control. I used fiery genesis lights in this example, a mix of five lights. Unfortunately, in DS I can't separate between lights as Photoshop. With AoA Advanced Ambient Light probably allows it. I will try with this when I can buy it.
    600 x 1200 - 322K
    600 x 1200 - 330K
    600 x 1200 - 319K
    Another quick experiment, trying with a subtle change in shadows "segmentation"
    600 x 1200 - 179K
    600 x 1200 - 169K
    Another transition type. There are three: sharp, smooth and noise. This is smooth.
    1000 x 1666 - 399K
    1000 x 1666 - 350K
