studio, failure to fire
ManStanManStan Posts: 0
edited July 2013 in Daz Studio Discussion
I just installed Studio 4.6 to this old comp; gatewayasaures rex. I don't really have room on my main drive so I installed it to my slave drive, but I get this "the procedure entry point?put-lastrecid.............. could not be located in the dynamic link library Vshared-release-x86.dll." error and it fails to start.
I'm not sure if I can fix it, and sure don't know how. Any help would be appreciated.
But I have this sinking feeling since I don't have an X86 folder on XP, this just isn't going to work.
Post edited by ManStan on
  • MattymanxMattymanx Posts: 7,002
    64 bit or 32 bit XP and are you installing the same (32 or 64 bit) of DS46?
  • ManStanManStan Posts: 0
    32bit to 32bit. The issue is Studio looking for some dll in the X86 folder. There certainly is no X86 folder on a 32bit XP system.
    I downloaded and installed DAZStudio_4.6.0.18_Win32.
  • mCasualmCasual Posts: 4,607
    edited July 2013
    on my win64 pc,
    the dll named Vshared-release-x86.dll is found in the same folder as daz studio 32-bit itself
    ( C:\Program Files (x86)\DAZ 3D\DAZStudio4 )
    on your 32-bit PC it should be somewhere like
    C:\Program Files\DAZ 3D\DAZStudio4
    the DLL for Daz Studio 4.5 is dated 10/9/2012
    from a quick search on the internet my guess is that it's a package of database functions ( created by Paradigma Inc.) used by Daz Studio's Content Management Service
    the error message you get could indicate that you are using a too-old or too-recent version of this file
    if this DLL is not in the same folder as daz studio, then Windows will look for it in places
    like c:\windows\system32 and it could be a very old version that was put there by other
    programs or even the stock version that comes with Windows .. and likely this version wont be compatible with Daz Studio 4
    i saw somewhere that the Daz Studio Content manager needs to run or be installed with Windows administrator privileges, so maybe maybe during the installation something prevented the installation of Vshared-release-x86.dll in the Daz Studio 4 folder
    Post edited by mCasual on
    Gets better. I can't uninstall studio the uninstaller errors out. I can't run the studio installer, it errors out. But I can certainly delete every little bit of it and not worry with it again.
    I fixed this by prepping folders. The issue was just installing to my D drive. I had to set up a DAZ studio/ My library folder, and a DAZ 3D/DAZstudio4 folder and all is fine on the reinstall. Of coarse then I had to reset my carrara browser; which I am having an odd issue with, but maybe this will fix it.
    Problem I am having now with studio is lacking in working space. I've reset the interface but the side panels still take up 2/3 of the screen.
