Remapping a figure
Is it possible to remap a figure in Hexagon to take a different figure's textures?  or add more shading domains to an older figure?
  • AscaniaAscania Posts: 1,855
    edited July 2018
    Possible? Yes. Worth doing? expletive removed, no! Use a program with better UV tools.
    Post edited by Chohole on
  • I use 3D-Coat for such things.
  • You do not need to re-map the figure to give it a different texture, if you have an artpackage which allows layers you could copy one to the other ( possibly using the clone brush) - Have you thought of buying a Merchant Resource from the store ?
     I do not think adding shading domains is a good idea, try it but I would imagine things would go horrible wrong when you get the character back into DAZ Studio.
    Not a different texture, a texture mapped to a different character.
  • Ascania, probably the way I see things in my head, I do not use other peoples textures but I can visualise how I could use layers to take a V4 character and put it a Genesis 8 map.
    If I've mis-read things (not understood things propperly) I'm sorry.
    Let's go with something distinctive: How would you put Posette's map on a Genesis 8 figure without remapping?
  • TSasha SmithTSasha Smith Posts: 27,397
    Um, Slight problems. I did not say I was taking the figure from Daz Studio in the first place.  I was thinking of a figure I found in the Poser default content not a Daz figure.
    True that is what I meant.
    Again I was not talking about a Daz figure but a poorly mapped figure found in the Poser content.
    You are now understanding me.  A figure from Poser defualt content might be Posette, but she is not the only one included that does not have the best mapping.  I found a figure called Gamma Girl.  I think she has potential if she is remapped and maybe rerigged or something.
    I missed these posts.
    Do not have 3D Coat. When I could have afford it, I went with ZBrush.  I assume the $99 version have some restrictions on usage.  Anyway I was having problems getting popcorn at a movie theater today which probably means no 3D-Coat for a while. Maybe Zbrush can work once I figure out how to remove the welcome screen pop up.
    o.0  Blender or ZBrush which one has better UV tools?  I have both.  Wait I did not buy Blender?  Shhhhh!  I found a free copy of Blender and am using it.
    Okay, my ride should be here soon so I can leave the movie theater.
    Here is my ZBrush pop up screen
    1063 x 609 - 377K
  • I have ZBrush. Don't use it though. Hate the artist's workdesk metaphore it uses.
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited July 2018
    Sorry folks, I thought you were talking about DS stuff :(
    Post edited by Wee Dangerous John on
  • Syrus_DanteSyrus_Dante Posts: 983
    edited July 2018
    @ Miss Bad Wolf
    This is the LightBox no one could avoid to pop up since ages but now we have a ZStartupMaster plugin for that.
    I prefer the Blender UV mapping where you can select edgeloops and mark them as UV-seams, then going to the UV-Image Editor and unwrap even section by section with various options.
    While in ZBrush you paint roughtly red vertex color to the areas you might want the UV-seams to be placed and blue vertex paint for areas you don't want to have UV-seams, then pressing a unwarp button and hoping ZBrush manages to get how you wanted your mesh to be unwraped - if not fixing and arranging UV islands with only brush tools is no fun. I'm talking about ZBrush 4R8 but don't think it has changed in 2018.
    Post edited by Syrus_Dante on
    @ Miss Bad Wolf
    Does that plugin work with ZBrush 2018?
