Issue Converting G8 to G3 (dforce)
I'm pretty heavily invested into characters and poses for G3, so for the time being, I'm just picking up G8 clothing I absolutely have to have, and converting it to G3 using SickleYield's tutorial. Last thing I picked up was the Wizard HD set. Conversion went beautifully for everything, until I came to the outer tunic. Now, after I've changed the Scene Identification and properly transfering the rigging (careful to select the figure first, then the article), when I actually fit the article to the figure, this is what I get:
Any clue as to what might be screwing this up for me? The outer cloak, which also drapes along the arms similarly to this article, made the transfer flawlessly.
  • Richard HaseltineRichard Haseltine Posts: 111,458
    How does the tutorial have you cope with the different zero positions for the arms?
    Did you try zeroing the figure before you fitted the garment to it?
    Laurie
  • TykeyStudiosTykeyStudios Posts: 892
    Laurie
    I was thinking the same. Looks like something might have been skipped in the process. I've had no issues using the outer robe on G3male and I converted the entire Wizard collection to G3.
