B25 Winter dress textures
PschelfhPschelfh Posts: 261
Are there any textures I'm missing for the B25 Winter Dress? When I apply the .ds materials from the 'Pose' directory, It's all still 'plastic' looking (like there's no material applied at all).
In the promos it all seems more like fabric/velvet + it's even displayed in different colors (which I also don't see in the materials) :
RM Nieves bundle (which I bought), picture on the left : http://www.daz3d.com/chrystalline-nieves-bundle
B25 Winter (the 4 pictures under the main one) : http://www.daz3d.com/b25winter
Included is a quick test render in DS4.6 with the materials applied.
Thanks for any pointers,
Peter.
    Do all the surfaces have texture maps applied, or just color with slider adjustments?
  • PschelfhPschelfh Posts: 261
    I have applied the materials from the 'Pose' map (.pz2/.ds) in my picture.
    I also tried the materials from the 'Materials' map (.mc6), but it's the same result.
    Peter.
  • KeryaKerya Posts: 10,943
    I am not on my render pc and this is a bit older ... are the .ds maps in the same folder with the pz2 or are they in a separate folder in content / people / V4 ...?
    By the way: there are free textures for this dress by Chohole
    http://chohole.ovbi.org/page_15.htm
  • scorpioscorpio Posts: 8,533
    They aren't very good surface settings for DS, this is an earlier product when usually if you got DS settings they often weren't very good.
    Looking at the promos it looks as if they have used velvet shaders there doesn't seem to be an image using the textures supplied, some items lost images when the shop moved it looks as if this was one of them, but it is very misleading.
    Yes, seems to be a limitation with this one, all my other clothing/textures work fine.
    No problem though, I have enough clothing shaders in my library that I can apply to this one. Just wanted to make sure I didn't miss anything.
    Thanks for your replies!
    Peter.
    These are very nice, thanks for the tip!
    Peter.
    If you dare to set your foot into the shader mixer (I am joking, it is not that scary!), I have my velvet setup here:
    http://www.daz3d.com/forums/discussion/25560/
