The How Much Does A Kilo of Chocolate Weigh Complaint Thread
1…3132343637…50
  • TJohnTJohn Posts: 11,448
    Jaderail said:
    I'll say this, the forums are buggy only when the Cloud Flair Servers are buggy. How can i know this? Because your NEVER really on the DAZ servers until the Cloud Flair PROTECTION front end sends your post, it's all cached on it and sent from them to DAZ and then from Daz to them and then to you. It all has a LAYER that is supposed to be invisible to the user but is not. In truth all the drop outs and such is caused by the front end and not the forums. That is why some folks never have a problem and others always do. The connection to the front end. It never happened very much until it was added. When it did happen the DAZ3D SITE was down for all users most times, not just buggy for some Users as it is now.
    I'm Not a fan of OFF site protection, but IMHO this is the only reason I know of that could cause some to not have issues and others to have them all the time. The Connection to the Middle Man from your location. That I'm sure is Routed in some way for every user. In normal talk, with Cloud Flair as the front end, we are on a MIRROR of the Forums, if the Mirror times out before DAZ3D gets your Action UPDATE (post) then that is sent back as a error to the Mirror. It comes down to the ROUTE to the mirror and from the mirror to the Site then back to the mirror then back to you the user. IMHO way to many IP route switches are possible when done this way. This causes Time out issues for some users when they connect to some routers from their location. It is also the reason the same user can get a Good connection sometimes, because the Routers are dynamic and its the luck of the draw which are in low use mode and the user keeps getting that bad connection over and over. If it is in low use Logging out and then back in will still send your connection right back to the router with the lowest traffic.
    That's My complaint: It happens to me Too but not often.
    Not that it never happens to me now, but since my local 4G signal came on line, I've had much fewer problems. This makes me think the speed of your internet connection may be a factor.
  • M F MM F M Posts: 1,388
    edited July 2013
    @Jaderail: And, of course, we can't side-step it >_<.</p>
    Putting your reliability and 'corporate image' into the hands of a disinterested third-party sounds about as smart as putting your life savings and superannuation in the hands of gambling addicts and felons (oh, wait...). This is all because the DAZ Inc server administrator couldn't handle (D)DoS attacks and other forms of "modern maliciousness', so they had to outsource their "web security" to create yet another weak link in the chain? To quote Misty, whisky tango foxtrot? I would have thought there'd be local "Internet security" firms available in Utah to allow them to use "local presence admins" to ensure 24-7-365 uptime, that would have been far less expensive than the current "solution". I've noticed in the past 48 hours or so that posting seems to be flakier than usual - hit Preview and the page just times out and does nothing, hit Submit and the update just times out the same. I did see a post from DAZ_Jon (or DAZ_someone) saying that they were 'working on a new solution', but that it wasn't ready for primetime yet....
    I can see from the angle of your post over in the other piano thread KK that I'm going to have to model the strings AND the pegs (>_<)... how many sides do you think I should use for the string? if I use only 3 or 4, it probably will reflect the light weirdly from certain angles... I'll perhaps try an 8-sided string and see how many polys that ends up being >_<. The pegs will be there... but I probably won't model the string actually winding around it separately (that would be WAY too many polys, for the 264 or so strings...).</p>
    Post edited by M F M on
  • SkirikiSkiriki Posts: 4,976
    Kyoto Kid:
    Free grand piano #1
    Free grand piano #2
    Free grand piano #3
    Would any of those work out?
  • DanaTADanaTA Posts: 13,414
    Skiriki said:
    Kyoto Kid:
    Free grand piano #1
    Free grand piano #2
    Free grand piano #3
    Two obj files and a DAE file. Obj files don't have rigging. I don't know what DAE is, so I can't say about that one.
    Dana
  • JaderailJaderail Posts: 0
    tjohn said:
    Snip!!!Of my Crap.
    Yep, speed of connection would really play into this, If your Speed to the Mirror is such it times out the speed from the mirrror to the Site is still your packet speed, the same on the route back to you.
    M F M said:
    @Jaderail: And, of course, we can't side-step it >_<.</div>
    Yep, nothing we can do. I've Pinged my IP route, I'm in the deep south east, I hit DAZ3D from... San Francisco Cloud Flair servers.
  • RezcaRezca Posts: 3,393
    DanaTA said:
    Skiriki said:
    Kyoto Kid:
    Free grand piano #1
    Free grand piano #2
    Free grand piano #3
    Dana
    DAE is supposed to be a Collada file, which usually doesn't carry over rigging details but sometimes (Depending on the Collada version) might. However, from my experiences the rigging is either not present or broken.
    Material zones and stuff are usually there. Depends on the application that's exporting the Collada file and often on the one importing it.
  • ps1borgps1borg Posts: 12,776
    Morning. Cool wind and bright sun in a blowing hot and cold sky outside my window today :o)
    Good morning, or in my case...evening...it's 7:24 here.
    Dana
    Well, now it's 7:29...damn site!
    gooDd eeve ning (dracul accent) :)
    why do they portray Odin as old? he's immortal int he?
    Dana
    *waves* Glorious sunrise this morning, perhaps sunset will be spectacular for you :o)
    An immortal sixteen year old wouldn't have gravitas :o)
    I'm physically OK.. nothing wrong blood glucose wise at all. Just real, real stressed and suffered one of my bouts of depression that can happen when I get real emotional.
    It's a long story and I won't bore you with it, but sometimes things inside my head get dark and I kind of go off.
    Sorry.
    I think I'm going to take a few days and just go offline and chill.
    So, don't worry!
    *hugs*
    AtticAnne said:
    Still nothing from WoolyLoach. I'm getting worried now. I don't have a number or address for him or I would check on him.
    This will explain some Anne http://www.amazon.com/kindle-store/dp/B0086WCHJG
    Rezca said:
    I 'unno if this sea dragon is a kilometer long, but it's still big very big! :D
    The human is only there for scale-testing, to give a sense of size and massive-ness. It's not even a real human :B
    I coulda put in a sphere or a cube or something, but we all know how big humans are so.... :P
    hehe a shark-whale?
    ps1borg said:
    Dana
    It looks pretty nice. We used to see much nicer sunsets in Fall River, where I used to live last century. But that's on the bay at the end of the Taunton River. I suspect sunsets are always nicer when near water like that.
    I have to hop in the shower and go out.
    Dana
    hehe a shark-whale?
    It's the handsome DAZ Sea Dragon =3
    Love that guy, but there's not many opportunities to use it D:
    Oh hey, when everyone was talking about oceans I forgot something...
    http://forums.cgsociety.org/showthread.php?p=7124146#post7124146
    A freebie scene anyone can use (Was meant to be used as a lighting / material challenge) that comes with a nice detailed ship and a stormy ocean prop. Comes in OBJ and FBX formats (ANd BLender and MAX and Maya, but all these are separate downloads.)
    edited July 2013
    i wuvvs the sea hatchling, so cute. hatchling on the half shell
    holy carps, squeets had a festival on my legs, 3 bites and 2 bites. iiiiitch. i was outside less than 30 seconds the other night, the sluggees were moving with energy with their squishee-move slime trail gave me heebeegeebees.
    and no calamine lotion.
    thinking about not watching the movie for t'nite, watched it 5 nights in a row, last night with close captioning on.
    the stars are out
    503 x 109 - 19K
    Post edited by Mistara on
    they made him older than Gandalf. Gandalf has only been around for 3 ages of men ... iirc
  • atticanneatticanne Posts: 3,009
    I'm on my way out of town for my oldest grandson's wedding tomorrow. I've never used a Kindle book. Must investigate when I get back home. Thanks for the link to shove me forward in my computer experiences.
    edited July 2013
    Thor 2 is supposed come out Nov 8th. squeeee it's a friday. and it looks like the weekend of veterans day. Loki is in it. will he ever be buds with his brother again?
    "shoot to thrill, play it again"
    there's only one movie theatre close enough for me to take a taxi. lame smaller screens. it sucksss not having a car.
    tee heee http://www.youtube.com/watch?v=dqrwsrEOA-A
    Chris H tells Chris E he can borrow the hammer prop ... if he can lift it, LOOOL
    Hulk couldn't lift the hammer, his feets mushed through the floor
    all wound up now and it's sleepy time. doh
    who needs a grip on reality? it's overrated.
    Where would movies be without sibling rivalry? :>D
  • kyoto kidkyoto kid Posts: 42,469
    ..yeah and that explains why I was hit with is so often considering my glacially slow connection.
    Skiriki said:
    Kyoto Kid:
    Free grand piano #1
    Free grand piano #2
    Free grand piano #3
    ...grabbed the .3ds (second) one as I learned I can just open then save it in a modeller as a .obj. Basically a nice Steinway A model which will look good in the studio of the London townhouse. The last one, while a full size concert grand, is unfortunately for Sketchup (.dae).
    ...well hit a snag with the new setup (currently at a late night hotspot).
    Apparently the connection I get is good, but when I start FF all I get are timeouts and Unable to Connect errors. Just got done with a troubleshooting chat session which gave me a few suggestions to try when I get home. Tried to get online with the old wireless, but I think it knows it's days are numbered for the connection was so slow, made the the life and death of a G2 type star (like our sun) seem fleeting.
    ...oh, while I'm here , another Xin Xin pic this time as a frivolous little fey.
    Used the standard SSS shaders on her
    A3 MFD with the Ferny Fairy texture by Fisty (freebie)
    May Hair - (beads retextured with AoA's Metallised Glass Shaders)
    Enchanted Wings with the Alley Sprite texture
    Leg and Arm bands from Zenia for Aiko3 - retextured with AoA's Metallised Glass Shaders
    One of Noggins' Flutterbys
    Woodland Realm Playset 2
    Lots of Lisa B's plants.
    AoA's Atmospheric cameras
    1000 x 1000 - 1M
    Kyoto Kid said:
    Skiriki said:
    Kyoto Kid:
    Free grand piano #1
    Free grand piano #2
    Free grand piano #3
    Talk to music2u4u...he has done a lot of conversions of Sketchup models.
    Dana
    Odd, I use FireFox all the time now and don't have any issues with it with my Comcast connection. It's actually faster than IE.
    Dana
    edited July 2013
    ...it's not so much the process, but more that Google no longer owns it so there is no more free version save for a`demo that has only a 4 duration.
    Post edited by kyoto kid on
    Dana
    ...for me it is just getting the service started. I have a link to activate it online but cannot get to the page to do it (cant even get the Comcast site itself to come up) because I keep getting the timeout/unable connect errors. IE is no better. Windows shows the connection itself to be fine so I don;t know what the issue is. I'm not all that savvy about networking so I don't know if there is stuff I need to do on my end on windows to get it to work.
