Movement gravity
Hi,
How can i do gravity movements of hair and clothes? is that how it calles?
Thanks
Hi,
Thanks
You may be able to use morphs in the hair, or apply dForms to move the hair. However, your options may be limited by the way the hair is made - some uses actual strandas, but a lot uses layers of mesh with a transparency map and those can't go far without looking wrong. There are a couple of hair sets that use dForce to drape, and a product that will try to add dForce options to standard hair (subject to the same limitations of how the hair was made).
For dForce use examples, please check out this thread: https://www.daz3d.com/forums/discussion/208141/how-to-use-dforce-creating-a-blanket-draping-clothes-on-furniture-and-much-more#latest
