turn shadows off on an object
alan bard newcomer
does this option found under parameters display work? or does iray ignore it?
haven't used it in the past .. but in this case the table is throwing an annoying shadow. Highlighting the double sided lighting.
is the more to controlling the shadows? than that setting or is it non-functional?
the render was done with the shadwo setting of the table turned off
Iray is based on real world, so you need to either change your lights or use canvasses so you can do what you want in Photoshop.
you can do it in Octane which is a physically based renderer so I reckon if DAZ wanted to they could implement it in iray too
but no us users cannot do anything but combine the table and the other render in postwork with the same lighting
While you can't turn them off, you can either use a light source that doesn't cast a lot of shadow (like, a mesh light), or if you have a spot light, change it from "point" to "disk" and increase the disk size. The shadow will blurr then. (I hope I described that correctly... Esha showed that in 'nuts and bolts' section of the DA Webinar about portrait lighting that was recorded yesterday. So much looking forward to today's practical demonstration!)
thanks... I was figuring that Iray ignored it.. but wanted to double check...
Yes, the shadows off works just for 3Delight.
