Why are the polygons visible on V4 (Iray converted) and what can I do about it?
dracorndracorn Posts: 2,379
edited June 2018 in The Commons
I did an Iray conversion of V4 - Warrior Maiden Ashe, and noticed in my final render that polygons are visible on the right hand, elbow and shoulder.  Why is this happening, and what can I do to fix it?
(click on pic for larger view)
Post edited by dracorn on
    you can try applying sudivision and/or smoothing to the figure.
  • SorelSorel Posts: 1,434
    Yeah need to add some subdivision. I have to do this in octane as well for Genesis even.
  • beyonder2k9beyonder2k9 Posts: 117
    Is that a setting in Daz?
  • BradCarstenBradCarsten Posts: 856
    edited June 2018
    Yeah. If a figure hasn't been converted to Sub-d you can convert it at Edit > Object > Geometry > Convert to Sub-d.
    Then under properties tab > mesh resolution > View Sub-d Level, you can up the mesh resolution level.
    Post edited by BradCarsten on
  • dracorndracorn Posts: 2,379
    edited June 2018
    That worked, thanks!
    686 x 515 - 45K
  • kyoto kidkyoto kid Posts: 42,411
    ...will adjusting the rendering SubD work?
  • glaseyeglaseye Posts: 1,312
    yes, the 'View SubD' setting is independent from the 'render SubD'
    ..excellent as polygon based subD tends to make the mesh "heavier" and take up more memory resources.
