Genesis wardrobe items want to autofit on Genesis
barbultbarbult Posts: 27,550
I installed the latest MFD for Genesis Expansion Pack 1 with the DIM today. When I select Genesis in the Scene tab and try to apply one of the wardrobe items (e.g. OSkirtEx1.duf, the overskirt), it pops up the Autofit dialog. Why? The wardrobe items show in Smart Content when I have Genesis selected, so they know that they are compatible with Genesis. The Autofit dialog does not pop up with items from the other Genesis MFD expansion packs I have - why this one? I'm kind of puzzled.
  • Richard HaseltineRichard Haseltine Posts: 111,546
    Try fitting it to the MFD
  • vwranglervwrangler Posts: 5,049
    edited July 2013
    I can verify the same issue. Moreover, it happens whether you try to fit it to the dress or to Genesis. In fact, it occurs even when absolutely nothing is selected in the scene, although I think that's because by default, the item tries to fix itself to Genesis if there's one in the scene. If there's absolutely nothing in the scene, Autofit doesn't invoke.
    Expansion Pack 1 was recently reissued to correct a morph error. Apparently, in the process of correcting one error, another was created.
    Reported as a bug.
    Post edited by vwrangler on
  • barbultbarbult Posts: 27,550
    Reported as a bug.
    Thanks for confirming the problem and writing the bug report.
