Does your version of "Gwen Hair" for Genesis 2 automatically fit to Genesis 2 female?
linvanchenelinvanchene Posts: 1,386
edited November 2013 in The Commons
edited and removed by user
Post edited by linvanchene on
  • RCDescheneRCDeschene Posts: 2,817
    I would simply uninstall the product and re-install it. But if that doesn't do much for you you should probably send in a ticket,
    I have a couple Genesis products such as clothing that do that as well.
    edited July 2013
    I noticed that when I use the .duf preset for "Gwen Hair Genesis 2" that Hair does not automatically fit to Genesis 2 female.
    Autofit for the last couple of D|S versions must have the Content Management System running. Do you use Smart Content or Categories, and have you noticed this and content searches also not working? If so, then the CMS has fallen over. It happens occasionally. To autofit manually, use the "Fit-To" in the Parameters tab, or right-click on the item and select "Fit-To" from the drop-down menu.
    How are you loading hair, clothes and stuff? Double-clicking from the Content Library or Smart Content is dependent on the CMS working and having the figure you're putting the hair or clothes onto selected. Another way is to drag the item from the Content tab onto your figure in the Viewport; this isn't dependent on the CMS, and should always kick Autofit into gear.
    Post edited by SpottedKitty on
  • linvanchenelinvanchene Posts: 1,386
    All other Gn2f hairs load fine. It is just "Gwen Hair Genesis 2" that gives me issues.
    Try drag-and-drop onto the figure instead of the double-click, see if that works properly.
