Booze Bottles with No Labels?
mwokee
in The Commons
I need a typical bottle without a label. Daz offer anything like that here?
I want to make a ship inside a bottle, etc.
A label is usually some texture map, that can be removed (go to the surface tab, select the label, go to "base" or "Diffuse", click on the small triangle, and from the list, select "none"), so you should be fine with any bottle. If you search the shop with "bottle" you'll find quite a few sets for purchase in all forms and shapes. Some may be older (pre-Iray), but as Iray comes with a default glass shader, it should be no problem converting them.
https://www.daz3d.com/potions-and-bottles
Labels and liquid can be hidden on the wine bottles for that one. (attached quickie iray render-- no manual conversion; just hiding the labels and liquid-- on both wine bottles).
All the bottles in Everyday Drinks have separate materials for the labels, so you can make them invisible.
http://fav.me/da254vt - freebie - they have lables but you can just replace the texture with a glass shader.
My set here https://www.daz3d.com/idg-night-out-props-and-poses also has the labels on a seperate material zone so they can be made invisible.
Be sure to post your ship in a bottle renders when you get them done. Sounds cool.
