Booze Bottles with No Labels?
mwokeemwokee Posts: 1,275
I need a typical bottle without a label. Daz offer anything like that here? I want to make a ship inside a bottle, etc.
  • BeeMKayBeeMKay Posts: 7,019
    A label is usually some texture map, that can be removed (go to the surface tab, select the label, go to "base" or "Diffuse", click on the small triangle, and from the list, select "none"), so you should be fine with any bottle. If you search the shop with "bottle" you'll find quite a few sets for purchase in all forms and shapes. Some may be older (pre-Iray), but as Iray comes with a default glass shader, it should be no problem converting them.
  • ChangelingChickChangelingChick Posts: 3,441
    edited June 2018
    https://www.daz3d.com/potions-and-bottles
    Labels and liquid can be hidden on the wine bottles for that one. (attached quickie iray render-- no manual conversion; just hiding the labels and liquid-- on both wine bottles).
    558 x 804 - 64K
    Post edited by ChangelingChick on
  • macleanmaclean Posts: 2,438
    All the bottles in Everyday Drinks have separate materials for the labels, so you can make them invisible.
  • deathbycanondeathbycanon Posts: 1,227
    http://fav.me/da254vt -  freebie - they have lables but you can just replace the texture with a glass shader.
  • DestinysGardenDestinysGarden Posts: 2,553
    My set here https://www.daz3d.com/idg-night-out-props-and-poses also has the labels on a seperate material zone so they can be made invisible.
    Be sure to post your ship in a bottle renders when you get them done. Sounds cool.
