How do I make an arc by typing in values? (SOLVED)
lukon100lukon100 Posts: 849
edited December 2018 in Hexagon Discussion
I can make arcs. But their values can't be set to precise values as by typing in the values to set the dimentions precesely.
How can this be done?
Example: Make an arc that veres to the right 90 degrees, begining at the precise tengent to the z axis.
Post edited by lukon100 on
  • AscaniaAscania Posts: 1,855
    Use a helper object and snap your arc to it.
  • lukon100lukon100 Posts: 849
    Thanks.
    What I ended up doing is just "drawing" circles and deleting segments of the circles.
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited June 2018
    Like Ascania I use helper objects to overcome little problems. Primitive or lines can be to place things in the correct place.
    A couple examples -
    Use a square, this will give you the points to snap an arc or circle from diameter. With the arc you choose the 1-3-2, in front view click on the left point of the square then drag to the right point and click, then move up/down and click when happy with the height.
    If you want to place something at 0.0.0 - Create a cube, move it below ground level. In face mode, choose the top face and change the Y to 0. Use the Lay-On tool to place the object (the lowest face of the object) onto the cube face.
    Delete the helper when finished.
    Post edited by Wee Dangerous John on
    edited March 2021
    edited March 2021
    edited June 2018
    Sorry, yes. Use SHIFT to snap to a point.
    edited March 2021
