lots of holes??
Hi I am modeling a mac pro tower. what is the best method for modeling the front alluminium with all the holes? I will exporting to bryce so i could use a bolean method in bryce to do this but is there a way to do this in Hexagon? thanks
  • AscaniaAscania Posts: 1,855
    An alphamap
  • Managed to solve this problem after looking through some previous posts here. just a small test section to see if it worked
    1140 x 1045 - 242K
    1093 x 1019 - 364K
    1037 x 1033 - 354K
  • barbultbarbult Posts: 26,608
    You are going to end up with a lot of geometry for very little benefit, unless you are rendering an extreme closeup of just the holes. A transparency map applied to the material surface would be much more efficient, I think.
  • Cool. You found a way. Hex shapes seems the way to go.
