How to parent a pendant to an existing necklace?
By using primitives, I've just made a small cross pendant that I want to hang to an existing necklace for G3F (I bought the necklace from DAZ).
When loaded, the necklace parents directly to the G3F character and follows all the moves and adapts to the proportion or size of the wearer.
I've exported the pendant as an obj, loaded the necklace on a G3K base character, imported the pendant and positioned it to the correct position.
Now, how do I parent the pendant to the chain, so it is linked to it and follows its movements?
Try following this post regarding smart props.
https://www.daz3d.com/forums/discussion/comment/919295/#Comment_919295
You can also use rigid follow nodes: https://www.daz3d.com/forums/discussion/203481/setting-up-items-with-rigid-follow-nodes-tutorial :)
I made a mother's day pendant for Jewelry Basics for Genesis 3 Female(s) which has a bone called "pendant anchor".
I loaded the necklace, put my pendant at the right place and smart parented it to the "pendant anchor" and then save it as a figure/prop asset.
