Show Us Your Bryce Renders! Part 4
1…3435373940…50
  • David BrinnenDavid Brinnen Posts: 3,136
    Great material effects Fencepost! A very nice render quality indeed.
    I'm still plodding on, in a somewhat dogged way, at trying to elicit different shading effects out of Bryce. Improvements are largely thanks to Horo's clever programming skills. I'm just "remixing" the results and faffing around the edges. There are a lot of possibilities now.
    800 x 800 - 134K
  • TapiocaTundraTapiocaTundra Posts: 268
    David, Sort of like this and the one before last, in a way these non realistic effects now are looking good and original. How and what is Horo doing with the programming.
  • Fencepost52Fencepost52 Posts: 513
    just for the fun of it I call this one "New Diet" It really is a sky in Bryce not a backdrop Dragons on the left and right have david and horo's metals with a few changes
    This is the kind of diet I need to go on! LOL Very nice. Did you model the dragons too?
    The hardest thing (at the moment) I'm really struggling to get my head around with Bryce is all the different shadow options. There's options in every menu, including those for the render settings, and I'm not sure which to use. UGH!!!!
  • srieschsriesch Posts: 4,243
    Is there something specific you are trying to do with shadows that you don't know how to do, or do you simply want to know what every shadow-related option does in general?
    I think it's probably the latter, Sean. I'm impatient. ;) I absorb knowledge quickly, but get frustrated when I can't put it to use as quickly as I wish.
  • GussNemoGussNemo Posts: 1,855
    @fencepost: That really turned out well.
    @Trish: That's a neat looking image. Sort of a bare bones image. :-) (still no smileys)
  • TrishTrish Posts: 2,625
    edited July 2013
    The mushroom is modeled in sculptris I turned it in to a glass ruby material could not put much with it because of the high poly count (I can not seem to keep that down) I get to playing in that program and it turns into something huge everytime.....oh well .....The really strange thing about this one is I found at least 4 figures in it after it rendered.....I call it "Poison Mushroom"
    Fencepost52: no I did not model the dragons I wish I was that good(bought him at daz)
    Guss; Thank you very much
    1228 x 613 - 617K
    Post edited by Trish on
  • HoroHoro Posts: 11,723
    @fencepost52 - Balls look really nice, materials are well chosen.
    @Trish - looks like in a museum, very nicely done. Mushroom looks interesting. You're quite good with Sculptris.
    @David - the outlines look perfect. For the last one I should have asked you whether you've played with Mindcraft again.
    Oh, just a modest converter, nothing to be afraid of.
    It's not that daunting. Important thing to know is that Sun/Moon Shadows in the Sky Lab is a global control. Set it to 0 and you'll never ever see a shadow in your scene, no matter how and where you set it. Keep it always at 100.
    Then, all the lights can be individually set for shadow intensity, IBL as well. There are hard transitions from shadow to light. Where that doesn't look natural - in a close-up render for instance - those transitions can be softened or blurred using Soft Shadows. This increases the render time because, if rendered with low quality (few rays per pixel), the soft transitions are noisy.
  • JamahoneyJamahoney Posts: 1,791
    "...high poly count (I can not seem to keep that down)..."
    MeshLab (Freeware - Downloads are on right of screen in link) can help reduce down the poly-count, I find. There, you would do: File/Import Mesh. Then: Filters/Remeshing, Simplification and Reconstruction/Quadric Edge Collapse Decimation. There are other options, too, like smoothing etc.,.
    If the above doesn't reduce down the poly-count in a single go, then save the now-changed mesh. Close MeshLab. Open it up again, and import back in the mesh again, and do all the Filtering stuff again to reduce the polys even more. Tried doing two instances of the above Filtering in MeshLab from a single launch, but it crashes (well, for me anyway).
    Cheers
    Good tip. I re-meshed the Stanford dragons and things with it.
  • Electro-ElvisElectro-Elvis Posts: 951
    edited July 2013
    Another attempt to make the impression of a forest with "faked" trees.
    1000 x 577 - 137K
    Post edited by Electro-Elvis on
    That looks quite good. What method did you use? Terrain spikes, or something else?
    Thank you Sean. You are right, I added 3 terrains with different spikes, one I smoothed a bit and the material is a variation of foliage of "vegetation"
    Looks really great at this size, very plausible.
  • mermaid010mermaid010 Posts: 6,291
    Thanks Chohole and Trish for the links to the Brushes. I also have a very old version of Photoshop, version 7. Normally if I need snow I use a soft brush, set the mode to dissolve and use a low opacity. Haven’t used the program in ages, so busy playing with Bryce.
    Interesting experiments from Horo and David. David’s Jade and the stylized effect one are my favs.
    Inspiring work by everyone.
    Electro-elvis, I’m impressed and inspired with how you used the terrains with spikes, thanks for sharing how you did it. Coincidently I watched David’s grass tutorial two nights ago.
    @Trish: Neat looking image. I tried Sculptris but could never get the hang of it. I may have to give it another go.
    @electro: Really nice, does look like an aerial shot of a forest and river. Well done.
    In this respect, we're twins.
    edited July 2013
    A few more new Peter the Polar Bear pictures.
    438 x 620 - 123K
    438 x 620 - 71K
    438 x 620 - 75K
    438 x 620 - 69K
    Post edited by Dave Savage on
    And another two for now.
    438 x 620 - 120K
    438 x 620 - 104K
    Shame you are not a PC member, one of they would do find for this months render challenge in the MO forum.
    Them is "Too Hot......Too Cold"
    Really sweet, Dave.
    Very cute Dave, wink back to the one winking at us. ;)
    edited July 2013
    Savage; I like him he is sooooo cute nice renders!!!!
    Guss; Don't give up on sculptris....I can only make simple things but its fun...
    Horo; do you know the programing language.....Axiom?????
    No. It was developed by Metacreations at the start of Bryce because it permits using the same code for Mac and PC. The language is proprietary and cannot be purchased.
    @Dave: Wonderful images. I think I'm partial to the Blue Jay sitting on Peter's nose. Nice job.
    @Horo: ...hahaha, I get that feeling a lot with several programs. I believe the fault of not catching on to Sculptris is my being much too impatient when learning something new. I feel the need to get it the first time and usually pack it in when it doesn't happen.
    @Trish: I haven't uninstalled it yet, so I haven't given up on it. At the moment, I'm rather like a kid in the candy store with so many programs to learn or play with. I can't decide which one I'll stick with until something nice results. Thinking about it, It may very well be the case of eating at a buffet. Some of this, a little of that, etc. :-) (smileys still not working)
  • RarethRareth Posts: 1,462
    Sculptris is fun to play with..
  • M1chaelFrankM1chaelFrank Posts: 0
    I'm a little hesitant to post this, as it's increasingly clear that I'm starting to move away from Bryce a bit... all the plants and background are Bryce, but the rock and ant are Zbrush. There are so many things that I prefer to do in Bryce, and I really wish I could stay in one program! Bryce is a longtime favorite of mine. I'm finally considering the dreaded upgrade to Mac, and fear I'll lose a great tool along the way, I really hate that.
    1280 x 1600 - 392K
    The ant looks amazing. You would be hard pressed to make it in Bryce using meta balls. It's a shame Bryce is not updated to work on the Mac. It appears that DAZ is completely focused on Studio (and content for it) at the time being. It's not only Bryce that gets no attention, Carrara and Hexagon don't fare better. This latest artwork of yours really looks awesome. It's so near to reality and at the same time it is a magical world.
    Magnificent work Michael Frank
    Inspired by Dave’s (TheSavage) recent mountain and cloud experiments, (a few pages back), I played around the same theme.
    Both these images started in Bryce5 a few years ago and shelved. For the 1st I used the Bryce volumetric cloud and for the second I used David’s volumetric cloud tutorials.
    http://www.bryce-tutorials.info/bryce-tutorials/volumetric-cloud-tutorial-1.html
    720 x 540 - 73K
    960 x 720 - 110K
  • StuartBStuartB Posts: 600
    @mermaid010
    Nice image.
    Have you tried smoothing the dolphins a bit.
    Just click the E on the little menu at the side of the dolphin object and move the slider on the left up to 100
    and click the smooth ball and then the tick..
    361 x 220 - 38K
