dForce Wizard Lore Outfit for Genesis 8 Male(s)
Using the clothing designed for the figure, and a pose designed specifically for the figure, and this still happens. I don't see any reasson for it...
  • LeanaLeana Posts: 13,478
    That's normal behaviour for long skirts/dresses/robes. You whould have bones in the robe to adjust the skirt position.
    Long skirts are not rigged to follow the legs directly, as in real llife they drape around the legs, they don't follow them exactly. Rigging a skirt to follow the legs leads to distortions and unnatural skirt poses: with the pose you used if the skirt was rigged to the legs they would be a lot of stretching in the middle, for example.
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2018
    This is a dforce dress, and supposed to be moved correctly during dforce simulation. A normally rigged dress would have bones in the skirt, as Leana said. You can try select the dress, go to the parameter tab and then under "actor", to see if there are any movements for the skirt.
    Post edited by BeeMKay on
    The product page lists those for the robe, not sure if they are bones or morphs:
    • Skirt Expand
    • Skirt Full Back OUT
    • Skirt Full Front OUT
    • Skirt Full Left OUT
    • Skirt Full Right OUT
    • Skirt Full Spread
    • Skirt Mid Back OUT
    • Skirt Mid Front OUT
    • Skirt Mid Full Spread
    • Skirt Mid Left OUT
    • Skirt Mid Right OUT
