Smart contents empty
2»
  • TotteTotte Posts: 14,752
    I did a clean reboot and CMS does not start when I double click on it.
    is your activity monitor set to show ALL processes, and did you start with the scripts? It wont start by clicking on it.
    And, if you check the logfiles for the CMS located in the CMS directory, /Library/DAZ 3D/Content Manager Service
    There is a folder named vlogs, in there are the logfiles from each launch attempt, it might give hints.
  • edited December 1969
    First, there is no files in the vlog folder and I enclosed another screenshot showing activity monitor and what i see when I start DAZStudio
    Also, you asked me if I start by scripts, so, because I dont know how to start by using a script, I suspect the answer is no.
    I cant believe I am the only one having this problem on the entire planet. I wonder how everyone else is fixing this problem.
    1999 x 1124 - 651K
    I used the new DAZ Content manager, so I assumed it loaded everything in the right place, but maybe that is not a good assumption. Where is smart content supposed to be loaded?
    OK, I went back into the blog folder and there are so many vlogs in there that it locks up my funder (spinning beach ball) every time I try to go in.....I mean there are millions of log files in there.....why so many?
    Here is what the VLOG folder looks like and its generating another vlog almost every minute
    1990 x 1119 - 1M
    edited June 2013
    It's pretty clear, it says "cannot open Master Database".
    So, in the CMS folder, in Databases, can you show whats in there.
    You can use the terminal
    (1) Start the terminal
    (2) type ls -ls Post the results here.
    I guess either the permissions prevents the CMS from being installed, or the database is wacked.
    If wacked, uninstall the CMS, remove all traces of it, reinstall it (by installing latest DIM or DS), then in DS do "reimport metadata".
    Post edited by Totte on
    So, its pretty clear to you but whats not clear to me are your instructions.
    1. I am new to Macs and
    2. I am new to DazStudio
    But I followed your instructions:
    Last login: Fri Jun 28 17:53:10 on console
    Tims-Mac-Pro:~ timwise$ ls -ls/Library/DAZ\ 3D/Content\ Management\ Service/databases
    ls: illegal option -- /
    usage: ls [-ABCFGHLOPRSTUWabcdefghiklmnopqrstuwx1] [file ...]
    edited June 2013
    a space between ls- ls and the path and you're OK
    Tims-Mac-Pro:~ timwise$ ls- ls/Library/DAZ\ 3D/Content\ Management\ Service/databases
    -bash: ls-: command not found
    tried it a different way but still the same
    Tims-Mac-Pro:~ timwise$ ls- ls /Library/DAZ\ 3D/Content\ Management\ Service/databases
    I said. you need a space between ls -ls AND the path, like this
    monster:~ totte$ ls -ls /Volumes/DazBoot/DAZ45CMS/Databases
    total 314944
    224 -rw-r--r--@ 1 root totte 114688 29 Jun 15:23 ContentDB
    2312 -rw-r--r--@ 1 root totte 1183744 29 Jun 15:23 ContentDB.blb
    88328 -rw-r--r--@ 1 root totte 45223936 29 Jun 15:23 ContentDB.dat
    219464 -rw-r--r--@ 1 root totte 112365568 29 Jun 15:23 ContentDB.ind
    4616 -rw-r--r--@ 1 root totte 2363392 13 Apr 12:24 master.vdb
    monster:~ totte$
    I did put a space after ls- AND ls.....its in the second entry
    ^ is the second space
    Yes, but there you typed ls- ls, not ls -ls
    Last login: Sat Jun 29 15:56:38 on ttys000
    Tims-Mac-Pro:~ timwise$ ls -ls /Library/DAZ\ 3D/Content\ Management\ Service/databases
    total 280
    216 -rw-r--r--@ 1 root wheel 110592 Apr 14 2012 ContentDB
    16 -rw-r--r--@ 1 root wheel 8192 Apr 21 2012 ContentDB.blb
    16 -rw-r--r--@ 1 root wheel 8192 Apr 21 2012 ContentDB.dat
    16 -rw-r--r--@ 1 root wheel 8192 Apr 21 2012 ContentDB.ind
    16 -rw-r--r--@ 1 root wheel 8192 Jun 29 15:58 master.vdb
    total 280
    OK, your database is very empty. Nothing seems to have been stored there.
    If you in DS try to Reimport Metadata, does it do anything?
    285 x 456 - 44K
    I am busy clicking on everything here but dont know how you got that pull down menu
    Select the TAB Content Library, then click in the menu icon just where the menu s topleft corner is in the screenshot.
  • edited June 2013
    Here is what I have to work with
    1990 x 1119 - 518K
    Post edited by timothyawise84_326aa8f1d1 on
    here is what I selected....see enclosure, but there is still nothing in smart content
    1990 x 1119 - 189K
    so I am looking at my content manager and I dont see anything in my content manager that indicates that any of it is smart content. Isnt there some smart content that comes with DAZ Studio?
    What constitutes smart content???
    1990 x 1119 - 219K
    Smart Content is content that comes with metadata, old content does not have metadata.
    how does one know what content has meta data????
    They have a checkmark in the Smart column in DIM.
    720 x 338 - 55K
