DS 4.6 64bit joint editor problem
I seem to have permanently turned the joint editor on, now everything I load displays bones when that item is selected.
Bone visibility is turned off in the parameters/display tab.
Clicking on Tools/ Joint editor does nothing.
    Doesn't selecting another tool, like the one for surfaces, change the display?
  • edited December 1969
    Yes it does! thank you for the tip :)...... I wasted hours trying to back track the tutorial I was following and find an off switch/button for joint editor when it seems none exists.
    You're welcome.
    All the tool buttons work like that. One 'has' to be chosen so simply choosing one makes the switch.
    You may find that some tools are best not to linger in longer than to do the task as the over all response of the program is affected.
    [why is because they are rather actively expecting to do something else than rotate the camera view for example]
