hexagon to 3d model plans
hi all i love using daz3d and just started experimenting with Hexagon, i also have a love of building R/C model planes and would like to know if i can use Hexagon for importing a .obj and then making plans from this so i can build a plane
any help is appreciated
Pete
photo is of the plane i wish to build
  • _ AL1vE __ AL1vE _ Posts: 191
    Pete
    you would need to have top, side, front, back, bottom in orthographic view
    an untriangulated mesh
    to do this select the outline edges for print needed and extract curve (menu: Tools > Lines > Extract Curve)
    any triangulated polygons need to be deleted
    make from each side needed a copy of the aircraft and repeat curve extraction for each top, side, back, front, bottom
    go into preferences: Edit > Preference Editor > 3D Display Tab > Advanced > Anti-aliasing checkbox selected
    choose for example as first print the top view, orbit around the aircraft that you almost view it from top
    at the very bottom of the 3D Viewport is a toolbar
    click the third icon from the right to left - this will allow you to switch back and forth between orthographic and perspective view
    use for each side of the aircraft orthographic view
    once you have the top view for example choose the very first icon from the bottom toolbar of the viewport - hover with your mouse over the icon and the tooltip should read
    "save current view as image file"
    this will allow you to save the viewport in orthographic mode as a image - you should choose PNG as there is little loss due to compression
    do this for each view needed and print them out
    if the resolution is too small you might consider constructing the aircraft from scratch in a CAD software like LibreCAD which is free of charge
    edited May 2018
    another probably easier method would be to download the blueprint from the blueprints website
    search for your aircraft and download it and print it out
    Dassault Super Etendard
    you need to create an account to download
    Post edited by _ AL1vE _ on
