General Freebie Requests
1…4041434546…50
  • robkelkrobkelk Posts: 3,259
    Here's the link to the Cookie/Chip/Peaches/Pickles freebie list.
    Please post there if you find more goodies:
    http://www.daz3d.com/forums/discussion/24271/
    Hope this helps!
    Thank you!
    (I was thinking everybody was looking at me... :-) )
  • andolaurinaandolaurina Posts: 676
    Hope this helps!
    Thank you!
    Actually, when the question was asked, you were the first person I thought of. But I looked & didn't see a list from you...unless I missed it!
  • caine collincaine collin Posts: 0
    Kerya said:
    Has anyone seen a free eye patch? Genesis preferred but almost any will work honestly :D
    http://www.sharecg.com/v/19025/browse/11/Poser/EyePatches-for-M3-D3
    Thanks a ton! :D
    Hope this helps!
    Thank you!
    No, the only "toon" list I have is for Sadie. (And right now I'm salvaging and updating the old forum's David/Luke/Laura/Matt/Maddie list when I'm relaxing from planning my parents' golden-anniversary party - which is this afternoon - so I don't have time to wok on a Cookie/Chip/Candy list.)
  • srieschsriesch Posts: 4,243
    This is a long shot, but is there any chance there are any high-quality dragon or dinosaur (T-rex, etc.) skulls out there? High quality just in appearance, it doesn't have to be even vaguely scientifically accurate. I found one dragon skull in the Renderosity freestuff section, but it was more of a general-use item and not really designed for extreme closeups. I found a free T-rex skull, but in some format that DAZ Studio doesn't use. You would think somebody would have a T-rex skull.
  • DollyGirlDollyGirl Posts: 2,718
    If the format for the T-rex skull is a .3ds format then all you need to do is open up Hexagon, import the .3ds file and save out as an object file. DAZ can read that format. You can use poser or Bryce to do the same conversion.
    Maybe Shukky's Bone horse will work for you.
    http://www.sharecg.com/v/36341/View/11/Poser/Shukkys-Bone-Horse
  • KeryaKerya Posts: 10,943
    Maybe you could contact Cybertenko at Renderosity? He had a Dragon Skull in the 2012 Holiday Giveaway ... if you ask nicely ...
    @Dollygirl, the T-rex skull is in .stl format from Autodesk123D at http://www.123dapp.com/123C-3D-Model/Tyrannosaurus-Rex-Skull-Fossil/597777 . I tried opening it in Hexagon, but it gave me an error message, and didn't look any farther than that.
    Thanks for the link to Shucky's bone horse! Unfortunately today isn't my day, that also gave me an error and didn't load in DAZ Studio, I haven't looked closer at it yet.
    @Kerya, thanks. I did find the dragon skull by Cybertenko, but I really wanted to zoom WAY in on it, and it isn't quite high enough resolution for what I was hoping to do.
    Well then here is the one I was referring to:
    http://archive3d.net/?a=download&id=13ce3c9d
    @Dollygirl, thanks, I grabbed that one and have successfully imported it through Hexagon (minus missing texture) and into DS.
    Does anyone know where I might find some garden plants, specifically vegetables like tomatoes, beans, herbs, stuff like that?
    What about salad?
    http://trumarcar.francemi.net/foodprops_tc.htm
    (scroll down a bit)
  • TeloxiTeloxi Posts: 21
    I'll probably get no reply like all the other requests I've posted...
    Is there, by chance (please let it be and free!) a face morph for Mike 4 that will hide the mouth? Or more exactly between the tip of the nose to the chin, making his face "look" like he's wearing a skin tight ski mask? Basically he'll have his eyes and nose but no nostrils nor mouth.
    I'm trying to create a really complex character but using so many duplicates of M4 on top of using a freebie mask (I found on sharecg.com) lags then crashes poser. I've even tried to load M4's obj into sculptris -which ate all my cpu/memory- in hopes of trying to create a custom exportable obj morph. I just don't have the knowledge, software and certainly not hardware to do this kind of work...
  • JesterVIIJesterVII Posts: 175
  • Eustace ScrubbEustace Scrubb Posts: 2,741
    JesterVII said:
    Thank you. Some of the best original faces use just enough of an extreme morph like this....
    Hasth thou a link to the mask?
    Thank you.
  • Tramp GraphicsTramp Graphics Posts: 2,435
    edited June 2013
    I recently picked up the Wet Body set from the Daz store, and, while a great set, it's definitely missing something, namely wet specular maps for "certain parts of the anatomy", if you catch my meaning. Anyone know where I could find, or knows how to make, such wet maps (particularly for males using the M4 gens UV map). Some seamless specular wet maps that could be applied to other types of surfaces would be cool too for use on cars, and "cybernetic prostheses" (replacing a given character's limbs), that could thus simulate water drops on such surfaces.
    Post edited by Tramp Graphics on
    edited June 2013
    You'll be looking for joequick: http://www.sharecg.com/joequick
    But it seems he's gotten rid of his nadinomask and suit...but this link might work:
    http://www.sharecg.com/v/67360/gallery/5/3D-Model/Quicks-Quick-Resource-Meshes
    and this one:
    http://www.sharecg.com/v/41994/gallery/11/Poser/M4-Mach-2-Free-Bodysuit
    Post edited by Teloxi on
  • edited December 1969
    Hi again, I'm looking for a free and easy way of making foot prints in snow. I'm using Daz studio 3 mainly because the newer ones have interfaces that intimidate me :D
    I havent found any good tutorials.
    and this one:
    hmm ... well these seem to be showing the areas of the face which, from your previous post, I understood you were going to have hidden behind a mask. In order to make a morph to accommodate that, one would need the mask so it doesn't poke through. At least for the way I morph things otherwise it's all guesswork.
    Possibly an image of what the goal is? Front and side view.
    I know I saw one, once before but can't seem to find it, I'm looking for a satchel along the lines of the one indian jones used .
  • EnigmaEvolvedEnigmaEvolved Posts: 1
    Wonder if anyone can help, looking for Genesis morphs. What I need is a rabbit face / ear and maybe foot morph.
  • joea64_bdfaa5ca94joea64_bdfaa5ca94 Posts: 298
    edited July 2013
    Back at the beginning of February, I asked around to see if there were a free V4 shoulder-to-waist sash available. One of the replies I got pointed me to this one by Nerd3D:
    http://www.renderosity.com/mod/freestuff/details.php?item_id=7904
    While it was originally designed for the P4 female model, I went back to get that item today but the Nerd3D site seems to be down. The other sash model I was referred to, Rose's Fantasy Elegance at ShareCG, does work with V4, but it's the wrong kind of shape for what I want.
    I still need a good V4 sash model like the one in Pageant Gear (http://www.daz3d.com/pageant-gear); that one is exactly what I want *but* it's for Genesis.
    Would it be possible for somebody to work up a simple shoulder-to-waist sash model that looks like the one in Pageant Gear that I can use for V4? I have a lot of fabric shaders (silk, satin, etc.) that I can apply to the item to get the colors I want. I've been held up on doing renders of a good V4 royalty outfit for months now because I don't have a satisfactory V4 shoulder-to-waist sash; I've tried converting the M4 sashes to V4 with Clothes Converter but the conversions, at least my conversions, don't work quite right on V4.
    Post edited by joea64_bdfaa5ca94 on
  • ElspathElspath Posts: 181
    I'm needing to find a good skin for an Indian (as in India). Needing it for some fanart. A free turban would be great as well. (Though I do have a turban on my wishlist but it is a bit expensive at the moment) Here is a reference pic for what I am doing. Thanks in advance!
    480 x 368 - 181K
    Try going directly to the site:
    http://www.nerd3d.com/catalog/product_info.php?products_id=17
    The closest free texture I know of to your request - and, while it's close, it isn't quite what you want - is Paola for V4:
    http://www.ageofarmour.com/3d/free/skin-textures.html
    But you may be able to use her anyway...
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    Get Miss digital creation here
    Turban here
  • tomhbwctomhbwc Posts: 24
    Hi, I would like to request a head morph for Genesis based on actress Allison Scagliotti (who plays Claudia Donovan on SYFY's Warehouse 13). Also, if it's not to much to ask, I would like a hairdo based on her's from Warehouse 13 (pre-Season 4).
    To see pictures of her for reference, search with google images "Allison Scagliotti warehouse 13".
    Thank you.
    That did it, thanks. I'll try converting it for V4 with Clothes Converter, but depending on how it turns out, I may still need someone to create a sash optimized for V4.
    edited July 2013
    I ran CrossDresser on the sash and successfully converted it and loaded it onto a V4 figure to test it. However, I have another problem. The sash drapes over the left shoulder by default, and I want it to drape over the right shoulder. I can't rotate the sash, though; neither y-rotate in Parameters nor y-rotate in the Universal Tool will turn the sash around. Is there another way I can "flip" it so that it drapes over the right shoulder instead of left? (I've attached a test render showing how it looks; I applied a satin shader in place of the default texture.)
    2000 x 1000 - 141K
