DAZ to Hexagon
CostelloCostello Posts: 97
edited December 1969 in Hexagon Discussion
Hi. I'm pretty new to modeling in Hexagon but wanted to make some changes to a pre-existing piece of DAZ clothing on the Genesis figure. I viewed a tutorial which lead me to believe that it was as simple as choosing the figure and then selecting Send to Hexagon. Unfortunately every time I do this, it opens briefly in Hexagon and then crashes.
I am running the latest versions of Hexagon & DAZ on OS 10.8.4.
I understand that there are some stability versions on Macs but was wondering if there were any simple steps I can take to make Send to Hexagon work more smoothly. Thank you in advance for your thoughts.
    edited June 2013
    Depending upon how you're getting the items into Hexagon, either tell D/S "no map" collecting or remove all the textures [including bump/disp] first.
    edit to add: I'm on W7 ... but have noticed that textures can often cause issues in Hexagon.
    Post edited by patience55 on
  • CostelloCostello Posts: 97
    I couldn't find the place where I could choose "no map" but I manually removed the textures and it transferred without crashing. Thanks, masked squirrel!
    You're welcome, glad it worked :-)
    The 'no maps' option shows if one is doing an .obj export from D/S [not via the bridge].
    Another little tidbit that happens for whatever reason is D/S tends to make an .obj file smaller in weight.
    I just imported a file into D/S that was about 78 mb from the Hexagon export; exported the very same file right back out with a new name. The new file is about 57 mb. Curious but useful at times!
