Trouble with Taylor hair
spswaffordspswafford Posts: 179
Just picked up Taylor hair from the Flash sale and wanted to try it out, but when I try to load it I get an error (see attachment).
I noticed the spelling of Taylor was "Tayler". Has someone run into this before? How can I fix so I can use?
Thanks,
Stefan
  • Richard HaseltineRichard Haseltine Posts: 111,701
    Are you sure the \Data\SWAM folder is in the root of one of your DAZ Studio content directories, not in a subfolder?
  • spswaffordspswafford Posts: 179
    I'm not sure, but I used DIM to install it.
    Make sure that the folders listed in the Installation tab of DIM's preferences (the gear at top-right) match the DAZ Studio and Poser content directories listed in Edit>Preferences>Content Library>Content Directory Manager in DS
  • mark128mark128 Posts: 1,033
    Thanks,
    Stefan
    I have Taylor installed by the DIM. I have that file in my library. I tried and the hair works fine.
    Go to your content library and see if any of that path exists.
    Check if the DIM really installed it. Select Taylor hair in the installed pane of DIM. Right click and select "Installed files..." (not 'Installer Files .."). This will bring up a window listing all the files DIM thinks it installed. find the dsf file on the list. Click on the file and it will bring up the directory listing with the file selected, if it is really there.
    Ok, found my stuff installed on C drive, which is odd since DS is setup on my F. Copied all the files over and it is working. Thanks.
