Moving DS content folder
I’m sorry if this has been brought up before I can’t seem to find anything about this issue when searching the forums.
is it possible to move the DS content folder “my Daz library” from the default at install location to a another location on a different hard disk in my PC?  Example moving from C:/user/documents etc to E:/ drive?
I know at install DS goes to a default location  but since I have some projects cooking moving the content folder would probably blow everything up.
thanks
  • LeanaLeana Posts: 12,936
    You can definitely have your DS library on an onther drive.
    How do you install your content, DIM, Connect or manually?
    Hey Leana,
    Well both ways actually I use the DIM and manually. I'm still new to DS and lately I've been using the DIM because it seems easier.
  • NorthOf45NorthOf45 Posts: 5,744
    This subject comes up every month or so. Here is one thread I bookmarked that has some pretty thorough instructions. Moving RUNTIME from HD to External HD?
    One good rule to follow: Copy first, then confirm, then delete.
