Another Noob question... Fillet/chamfer
So I'm trying to make a window, thing is it's NOT square; having rounded corners. (see image.)
For the life of me, I cannot figure out how to do a radial fillet in Hexagon, is drawing a rouugh guesstimate line my only option?
Figured I would do the "Easy" part first, but this has taken me most of the day, and I'm either missing something completely or just not understanding how Hex does this type of thing.
Any help much appreciated.
In image, trying to make the right-hand side plane, look like the left hand side window template.
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited May 2018
    The tool I would use to achieve this is the Chamfer tool. This does look a lot but it is quick and easy once you've done it a few times :)
    1. Make a square
    2. Select the points and choose the Chamfer tool - Adjust settings (Click lightning bolt)
    3. Copy and Paste the curve, adjust size of new curve
    4. Select the Ruled Suface tool then click on the curves in turn  (Click lightning bolt)
    5. Select edges then use the Bridge tool to fill hole.
    1920 x 1080 - 340K
    Post edited by Wee Dangerous John on
  • ViallyVially Posts: 348
    Thank you, took me a bit to get teh process down, but I now have the correct shape to a simple plane...
    Now is there a way to get depth to this? This is to be a window frame, so needs to have a thickness. I've tried to copy and then bridge. but the thing just stares at me like I'm stupid. (and I am really starting to feel that way.)
    Whoa...
    And suddenly it works the way I thought it should... Got it, thanks :)
  • Luftsturmregiment40Luftsturmregiment40 Posts: 328
    edited May 2018
    you can make a cube
    ring selection of the edges that you have four edges selected then chamfer and put more divisions in until it's round enough
    select the front face extract it and delete the remaining
    you have then a perfect rounded window
    1920 x 1080 - 455K
    1920 x 1080 - 532K
    1920 x 1080 - 412K
    1920 x 1080 - 417K
    1920 x 1080 - 413K
    1920 x 1080 - 438K
    Post edited by Luftsturmregiment40 on
    edited May 2018
    1920 x 1080 - 557K
