Quick fix needed on not having shine on skin
I am working on recreating an old couple I used back with V4 & M4...I couldn't find a male skin texture that worked with G8M so I am using a G8F...I'm okay with everything else but no matter what lighting I use there are these shiney spots on the skin and I cannot figure out what I need to do to fix it...I am not a complete newbie but I also don't understand a lot about the settings...
  • cm152335cm152335 Posts: 421
    edited May 2018
    under IRAY, at surface setting "base mixing" there is 3 option,
    - metalicity, - glossiness, - weighted
    by default all "skin" use "metalicity" for "mat" non reflection skin the weighted is what you need
    Post edited by cm152335 on
  • RJGirlRJGirl Posts: 93
    edited May 2018
    Thank you!!!! I will give that a try!
    ***And it worked wonderfully!!!
    Post edited by RJGirl on
