Quick fix needed on not having shine on skin
RJGirl
I am working on recreating an old couple I used back with V4 & M4...I couldn't find a male skin texture that worked with G8M so I am using a G8F...I'm okay with everything else but no matter what lighting I use there are these shiney spots on the skin and I cannot figure out what I need to do to fix it...I am not a complete newbie but I also don't understand a lot about the settings...
1200 x 1200 - 311K
under IRAY, at surface setting "base mixing" there is 3 option,
- metalicity, - glossiness, - weighted
by default all "skin" use "metalicity" for "mat" non reflection skin the weighted is what you need
Thank you!!!! I will give that a try!
***And it worked wonderfully!!!
