She's not as pretty as I thought she'd be....
NedKellyNedKelly Posts: 63
You know, I really thought that Victoria 6 would have been prettier than this.
    Goto My Account / Product Library, type in "genesis 2" into filter, download then install. Or if you use DIM it should in the stack to download and install.
  • NedKellyNedKelly Posts: 63
    Yeah, I've tried installing it with the DIM and manually but after three attempts with both methods this is still the result. There are files missing according to DAZ4.6.
    486 x 320 - 24K
    1139 x 715 - 78K
  • fixmypcmikefixmypcmike Posts: 19,731
    You need to install "Genesis 2 Female Starter Essentials".
    I have installed “Genesis 2 Female Starter Essentials”. I have installed it and uninstalled it and reinstalled it but it is missing some files. I am currently searching my drives to see if the files maybe installed to an unmapped directory but failing that then I have no idea what is going wrong.
    They are in the manually downloaded DIM folder. You can get that, unzip it and slide the files you need into place.
    Ok, I got it working by running the DB Maintainance program so not really sure what the issue was but it's all good now.
