Molly HD for Genesis 8 Female bag ?
“Growing Up for Genesis 8 Females” installed
Mod Edit, please do not post nude images. THis is particularly important when they are teenage or below.
  • Kristinka VlasovaKristinka Vlasova Posts: 16
    edited April 2018
    Image removed
    edited April 2018
    Image removed
  • Richard HaseltineRichard Haseltine Posts: 108,608
    Blurring is not an acceptable way to avoid nudity. please see https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
    Moving this to technical help as it is a question, not a Product Suggestion.
    If you are having issues with the shape switch the display to Smooth Shaded and your screen shots will be OK - you can do that by clicking the sphere ison to the right of the camera/view picker button at top-right of the Viewport. Also please describe the issue as well as posting images.
    That looks as if the rigging is not adjusting to the shape, but you may be confusing matters by using the Joint Editor tool - try switching to (say) the Universal tool and see if the issue is still there.
  • fastbike1fastbike1 Posts: 4,079
    edited April 2018
    Better yet, just use the sliders in the Parameters tab.
    Post edited by fastbike1 on
    Ah, yes - if you were trying to pose the figure with the joint Editor that would definitely cause issues - that tool is for placing the bones within the figure, it isn't for adjusting the figure through the bones.
  • I did not edit anything. I just call the model from the library two times by clicking on the icon Molly HD
    How did you pose it, it's not in the default pose in your screen shot.
