Adding to Cart…
Also just in case you don't know if you right click on a pose you can select "show in folder" then you can copy and paste the folder address from the top of your window into the program.
Ok, so then I do need to locate all the pose folders in my library first. I was afraid of that. LOL
Thanks for this information. As a new user, I am happy to come across time saving tips!
So, can anyone confirm that I can simply load up My Library/Runtime/Libraries/Pose and then convert. I see that this folder has a lot of the V4 pose files, but it also has more than just poses. Is this a problem?
*** So I am running the batch right now. I chose to Turn Off all Limits. So hopefully the end results will work correctly.
Thanks
I got a full set of the converters just a few weeks back, that lets me convert everything from Generation 4 all the way up to Genesis 8. Massively useful, and I don't think I've come across a pose it won't work on yet.
Just one IMHO small gotcha; the buttons to select source pose location are at the bottom of the dialog, and the buttons for destination are at the top — the opposite to the way I think. I figured it out quickly, though.
So I ran my first test and converted V4/M4 poses that were in the /Runtime/Libraries/Pose directory. Everything seemed to go ok and now all of these have been converted to G1. I think everything went ok from a few quick tests though some poses see to have some oddities with hands. I did set it to Turn Limits Off. Not sure if I was supposed to do that though. I actually also went through and deleted folders from the output that didn't seem to be worthwhile such as Emotiguy.
Now what I want to know is how to convert G1 to G2/G3. Is this possible? Also, I do have the G3 to G8 and G2 to G3 Pose Converters as well but I am not sure what Zforearm unlocker is. Can anyone explain this? Is there a missing manual somewhere for all of these products?
Thanks
I convert like this:
V4-Genesis 2 female pose converter: https://www.daz3d.com/v4-pose-converter-for-genesis-and-genesis-2-female-s
I then take it to Genesis 3 female using:
Genesis 2 female to Genesis 3 female: https://www.daz3d.com/pose-converter-genesis-2-female-s-to-genesis-3-female-s
Then Genesis 3 female to Genesis 8 Female: https://www.daz3d.com/genesis-3-to-genesis-8-pose-converter
I prefer pose converters I do not need to unlock arms and legs when converting. It saves time.
I should state I use this to convert male poses. I have no use for female poses.... So I convert M4 poses using the v4 conversion tool.
Well, the point of my query is not how to go straight from V4 - G2/3. What I am after is mass compatibility. So convert my V4 to G1, G2 and G3 but also convert other G1 pose sets to G2 and G3 as well. (not to mention G8). So it seems like the only piece missing here with the pose converters I have is a G1 to G2/G3 option. And also I don't understnad this whole Forearm Unlocking. I am not clear on what to do with it. Do I load up a G2 character, then load the Unlocker and then run the conversion?
For genesis you need a product like handy dandy to bring them to gen 2 https://www.daz3d.com/handy-dandy then you convert as usual
The unlocker has to be applied to each pose which is why its kind of frustrating. Its not a tool like the converter which does them all at once. You have to use it one at a time. Thats why I don't use scripts that need it.
Wait so Handy Dandy converts entire pose? Not just hands?
So the G2 pose converter by Zev0 doesn't work like the V4 one? You can't batch the whole folder? Does it prompt you to use the unlocker each time or something?
Sorry. Its late. And I don't intend to confuse you.
The poses for earlier figures apply to the later figures but require adjustments. Its been a while since I've used handy dandy but basically you can click and apply say an genesis pose to genesis 2 and then use handy dandy to reset the hands and feet. It doesn't convert anything per se. It adjusts it. You can save it if you want as a pose though. For a long while handy dandy was the only way to use poses from previous generations.
All the pose converters do batches. Its just whether you have to unlock the limbs after... The V4-to genesis 2 does not. Neither do the other two I listed. I am not sure about the ones you have. IT should say if a foreamr unlocker is included... In the docs.
Thanks. Yeah the whole problem is that there are no docs for these products from what I can tell. And no one seems to know how the Unlocker is supposed to be applied. I see also a Pose Corrector for the G3 to G8 pose converter, but again I can find no info on when you run this in the process.
Use the gen 2 to 3 converter the same way you did all the others. If I remember correctly the arm unlock says something like use the arm unlock before using the converted poses, or maybe it says that after conversionI don't remember. Anyway after your poses are converted and you want to add one of those poses to a G3 you click the arm unlock, then click the pose. Honestly I forget about half the time and the pose still looks fine. I only ever unlock the arms once per figure even if I'm trying multiple poses with it.
V4 to genesis and genesis 2 requires no arm unlock. So you are fine using that to conver v4 to genesis. you need to unlock nothing
Pose Converter Genesis 2 Female(s) to Genesis 3 Female(s) also does not rquire unlocking.
Genesis 3 to genesis 8 does not require the arm unlock. It does however include the 'corrector' option. This is for users who want to apply gen 3 poses to gen 8 but not convert them. You would apply the gen 3 pose to gen 8 and use the corrector. If you run the mass conversion though, this is not required.
Looks like you found the official support thread. It's a good idea to look for those. You will normally find them as they should be marked Commercial.
https://www.daz3d.com/forums/discussion/51586/pose-builder-pose-converter-support-thread-commercial/p16
I think that if you turned limits off, you dont need to use the forearm unlocker. I seem to remember using it only once to see what it did and then never touched it again.
Jeez this is taking forever. Batch has been running for nearly 24 hours. And that is just converting V4 to Genesis. And I am on an 8-Core Mac Pro. Yikes.
The v4 conversion process does take a long time. The other scripts are much faster.
So running the G2 to G3 script and noticed that it is not loading the character and pose in DAZ Scene. So it is doing this one behind the scenes? Definitely moving fast. Hope it is working correctly.
