H2 - Scale Edge Loop from center
sadicussadicus Posts: 14
edited December 1969 in Hexagon Discussion
1) How to scale from each center of selected edge loops?
in this example, several edge loops are selected but need to be scaled from their individual centers.
2) How to initiate a cube with x divisions?
in this example i need a cube with 7 segments.
  • Design AcrobatDesign Acrobat Posts: 459
    Type in a value in the scale part for "X" in the properties tab.
  • sadicussadicus Posts: 14
    yes what you suggest does work, however, I forgot to mention the selected loop needs to be extruded. :)
    Silo Workflow:
    1) Select Faces
    2) Double Left Click to select Edge Loops
    3) Extrude (but dont translate position)
    4) Local Scale Extrude (In or out)
    In Hexagon I have tried:
    Sweep Surface - Scale & Width Channel Box does not allow for data entry(?)
    Extrude Surface - Scale & Width Channel Box does not allow for data entry(?)
    Hexagon Workflow or( Workaround1)
    1) Select Edge Loops
    2) Extract Edge Around selected loops x2
    3) Disolve Center Edge Loop
    4) Select Center Faces
    5) enter value in Size: X, Z
    edited June 2012
    example
    897 x 959 - 69K
    Post edited by sadicus on
  • AscaniaAscania Posts: 1,839
    2) Bevel loops
    edited June 2012
    NOT FOUND:
    Bevel Loops
    .....Are you sure you don't mean "Extract Fillet"?
    Learn to discern the signature from the actual post.
    Bevel is in the same place you found the edge extractor.
