Connect fails after first successful product is installed
Overdrawn
When I select more than one product to update or install, they all start in unison (which is fine), but as soon as the first one is installed successfully, the other ones fail to complete. I generaly then cancel the others or restart Daz Studio and begin the installation again.
Additing another one to the install queue doesn't seem to fix anything--though I'd hoped it would trigger a reconnect or something. :-/
Her's the log output from my most recent attempt:
2018-03-05 09:31:18.603 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=100542018-03-05 09:32:11.388 Beginning Update of "Damien Demon for Genesis 3 Male(s)"2018-03-05 09:32:11.403 Beginning Update of "Creatura-The Black Widow for V4"2018-03-05 09:32:11.419 Beginning Update of "OnFleek for Genesis 8 Female(s)"2018-03-05 09:32:11.419 Beginning Update of "MRL Mutations"2018-03-05 09:32:55.673 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:34:57.745 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:35:33.174 "Creatura-The Black Widow for V4": Update Succeeded.2018-03-05 09:37:26.997 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:40:02.065 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:42:45.307 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054Below is the log from when I added another product to the queue--happens just after the last line above.
2018-03-05 09:43:09.656 Beginning Update of "Alternative Piercing Pack for Genesis 8 Male"2018-03-05 09:45:57.393 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054I'm not sure what's causing it, but it's grately hampering my use of Daz Studio...
Thanks for any help anyone has!
Post edited by Overdrawn on
If I do them one at a time, things work fine...
This is still troubling my use of Daz. It essentially means it takes days to get my new purchase installed. Installing things one at a time is painful...
Here's my most recent batch of errors (only installing one product this time...same error though...):
What security software are you using? Have you looked at the PostgreSQL and Smart Content help and troubleshooting sections of the Help Centre https://helpdaz.zendesk.com/hc/en-us ?
So. It's been working better today--though I've only been installing (not also trying to make something). Consequently, I think it's server-side not client-side.
Regardless, I'll keep an eye on it, and dig through those options. Thanks!
I almost always select multiple items to install in the Install pane and I've never had an installation fail that I can recall.
It seems this isn't actually related to multiple project installations...I just get the error randomly whenever I install anything:
Sometimes things install smoothly, but sometimes they just hang for awhile with that error message one or more times in the log file.
Like right now it's happening a lot... Is this just a general "server busy" sort of error from the Daz side?
