Connect fails after first successful product is installed
OverdrawnOverdrawn Posts: 592
edited March 2018 in Daz Studio Discussion
When I select more than one product to update or install, they all start in unison (which is fine), but as soon as the first one is installed successfully, the other ones fail to complete. I generaly then cancel the others or restart Daz Studio and begin the installation again.
Additing another one to the install queue doesn't seem to fix anything--though I'd hoped it would trigger a reconnect or something. :-/
Her's the log output from my most recent attempt:
2018-03-05 09:31:18.603 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=100542018-03-05 09:32:11.388 Beginning Update of "Damien Demon for Genesis 3 Male(s)"2018-03-05 09:32:11.403 Beginning Update of "Creatura-The Black Widow for V4"2018-03-05 09:32:11.419 Beginning Update of "OnFleek for Genesis 8 Female(s)"2018-03-05 09:32:11.419 Beginning Update of "MRL Mutations"2018-03-05 09:32:55.673 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:34:57.745 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:35:33.174 "Creatura-The Black Widow for V4": Update Succeeded.2018-03-05 09:37:26.997 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:40:02.065 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-03-05 09:42:45.307 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
Below is the log from when I added another product to the queue--happens just after the last line above.
2018-03-05 09:43:09.656 Beginning Update of "Alternative Piercing Pack for Genesis 8 Male"2018-03-05 09:45:57.393 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
I'm not sure what's causing it, but it's grately hampering my use of Daz Studio...
Thanks for any help anyone has!
Post edited by Overdrawn on
  • OverdrawnOverdrawn Posts: 592
    If I do them one at a time, things work fine...
    edited April 2018
    This is still troubling my use of Daz. It essentially means it takes days to get my new purchase installed. Installing things one at a time is painful...
    Here's my most recent batch of errors (only installing one product this time...same error though...):
    2018-04-07 21:00:14.697 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=100542018-04-07 21:01:07.904 Beginning Update of "Young Minto and dForce Minto Outfit for Genesis 8 Female(s)"2018-04-07 21:01:17.759 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:02:39.863 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=100542018-04-07 21:04:29.111 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:06:28.208 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:08:29.390 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:10:42.685 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:12:58.769 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=100542018-04-07 21:15:32.846 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=02018-04-07 21:18:14.207 WARNING: cloud\dzcloudtasknotifier.cpp(178): Failed to read https://cloudload.daz3d.com/encryptFiles/51/51303/5c95ae2e55a14d14e27661e7e2031dfe_9da638.enc trying again, curl error was: Failure when receiving data from the peer2018-04-07 21:18:37.127 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
  • Richard HaseltineRichard Haseltine Posts: 111,348
    What security software are you using? Have you looked at the PostgreSQL and Smart Content help and troubleshooting sections of the Help Centre https://helpdaz.zendesk.com/hc/en-us ?
    So. It's been working better today--though I've only been installing (not also trying to make something). Consequently, I think it's server-side not client-side.
    Regardless, I'll keep an eye on it, and dig through those options. Thanks!
  • barbultbarbult Posts: 27,495
    I almost always select multiple items to install in the Install pane and I've never had an installation fail that I can recall.
    It seems this isn't actually related to multiple project installations...I just get the error randomly whenever I install anything:
    Sometimes things install smoothly, but sometimes they just hang for awhile with that error message one or more times in the log file.
    Like right now it's happening a lot... Is this just a general "server busy" sort of error from the Daz side?
