*closed* RRRR Judged by the cover voting thread
Totte
It's time to vote in the RRRR Judged by the cover contest.
Anyone can vote, not only those participating in the actual contest. You can vote for any entries except for you own entries, and we vote in two categories, Best and Funniest. Best is more of a traditional render contest voting where funniest more takes the humorous look at the image. Some images have a few lines of text explaining the story behind them, which often helps the voting, specially in the funniest category. Each win (1st to 3rd place) will also give the winner at least one sticky Lucky Bastard pull, which means the next round will be a little harder, see below for how wins and Lucky Bastards are counted. We have changed the dropoff of Lucky Bastards so you will loose at half of Lucky Bastard earned the previous round, and set a maximum of seven LBs affecting your pull, if you have more, you will just pull seven a little longer.
Vote here: RRRR Voting
Entries are here: RRRR Judged by the cover entries
So, what are we voting about?
Winner in the Best category
- $5 DAZ GC
- 1 item from Dumor3D's store (no DOs or Bundles)
Winner in the Funniest category
- $5 DAZ GC
- 1 item from Totte's (Code 66)'s store (no DOs or Bundles)
2nd in the Best category
- $3 DAZ GC
2nd in the Funniest category
- $3 DAZ GC
Third in each category
- $2 DAZ GC
The voting starts now, and ends Sunday April 22 2018 - at 23:59:59 local DAZ Time
How votes are tallied and summed up:
Voting points: 1st = 5 points, 2nd = 4 points, 3rd = 3 Points, 4th = 2 Points and Tiebreaker = 1 Point.
If an image gets 1st, two 2nd, one 4th and two tiebreakers in a category, that is 5 + 2x4 + 2 + 2x1 = 17 Points
Every image points per category is summed up, and top three is calcutaled in each category. As we now have five prizes, a maximum of two entries from the same artist can end up top three in each category, this is to spead the joy a little more.
The image with most points from the same artist will be the base, the the average score for up to for other images will be added to that score, but if that image takes a top three placement, images who got to the cream of the crop with help from other entires, will gain extra LBs based on how many places it climbed, minus one. Here are two examples:
Example 1: The top image from X has 15 points. X also has five other images that has been voted for, 10, 8, 7, 7 & 5 points. Thaking the average of the first four images behind the top one is 10+8+7+7 = 8, so the first image which was at 4th place, now gets 23 points and rises to the top and becomes the winner. But, that image climbed 3 steps, so it will not only win, but give the winner 3 LB for the next run.
Example 2: The top image by Y has 11 points, and the second image 9 points. The top image will now have 20 points and go from 5th place to 3rd place, granting Y 2 LB for the next run.
If two images ends up with the same score, we use the same rules as in the European Song Contest, the number of higher scores wins over many lower scores, so if one image has 5+5+5+1 (16) and another has 2+2+4+4+2 (16) the first one will come before.
To avoid votespamming, anyone voting needs to post here in this thead that they did vote, and use the same name as they have posting here as the DAZ Forum name in the first question in the vote system at SurveyMonkey.
Remember to vote in both categories and place all five votes in both categories. Votes that fail to vote in both categories and votes faling to vote 2nd to 5th place will be discarded.
@Totte, I've PMed you.
Fixed!
Thank you. Voted.
I voted!!
Voted - Great work all!
Voted. Well done.
I voted.
Voted. Great job everyone.
Yes for sure everyone did an amzing job on their renders!!!
Yes, harder than I thought. All of them quite good.
best wishes!
Wow so excited to hear the winners!!!
But in my opinion everyone is a winner!!!
It was rather hard, but I ve voted
Good luck!
I voted! :) I forgot how much you all make me laugh!
Voting closed!
The best of luck to each and everyone!!!
Is the winners going to be announced soon?
Totte must be having a hard time counting the LBs lolz!
Hi,
I've been busy but I will try to get it done over the weekend (and we have a holiday here on tuesday as well so)
Oh ok, What holiday do you guys have going on there on Tuesday?
It's something that only some really care about, May 1st (but Sweden was ruled by social democrates for 90 years so they love thier "workers day holiday".
Winners announced!
https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
