Sometimes I can't remove an expression without zeroing a character..
Serene NightSerene Night Posts: 17,705
Hi:
I love expressions, but some sets seem to not reset when I use included reset expressions presets. Is there a way to reset the pose of the head to get rid of whatever funkiness is going on with the expression?
  • SixDsSixDs Posts: 2,384
    At the risk of telling you something that you already know, the easiest way is to use the Undo function under the Edit menu, but that would require that the pose was the last change that you had made. Alternatively, you could select the head, then Edit > Figure > Zero > Zero Selected Item(s) Pose.
    Yeah sometimes these days I can’t zero just the head pose. It does nothing.
    Hmmm, I don't think that is normal. I don't know if it will make any difference, but I guess you could try Edit > Object > Zero > Zero Selected Item(s) Pose, and see if that works. What figure are we talking about here? Do the expressions show up as sliders under the Parameters tab by any chance, or must they be loaded individually?
  • PetercatPetercat Posts: 2,324
    You could select the head, then in the Parameters tab, click on "Currently Used", then Alt/leftclick on everything that shows.
    If some things don't change, like "eyes up/down", choose them in the Scene tab and zero them out in Parameters.
