Time for School for Genesis 2 Male(s) export to unity clothes is transparent
Thanks the PBR shader type in Unity. It has dropdrop menu for the different material zones.
Sorry can you maybe lot a screenshot where this is
It in in Unity under the shader material section for model chosen. It will be about 2/3rds the way down the list although on complicated gameObjects you might have to scroll down to find the shader section for the material. The material will be abover the shader. If you click on the circle with the black dot in the middle for the material you can change the material being used for that segment of the FBX/model. That whole section is called the 'Inspector' tab and will be on the right to the main viewport once you select the model with the relevant material in the viewport.
