having trouble with the Pit Fighter Outfit
LycanthropeX
No matter what I try I get the following error when trying to load the pit fighter outfit in Poser Pro 2012 or 2014
D:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\lib\genericpath.py:94: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
sepIndex = max(sepIndex, altsepIndex)
Exception in RealityDataModel::addObjects: NULL result without error in PyObject_Call
I have tried reinstalling the outfit many times, I have reinstalled DSON many times, I have reinstalled both 2012 and 2014 many times, nothing seems to be helping. This is the only outfit failing to load with DSON, everything else is working fine.
I have run out of ideas of what to try next. Any suggestions would be helpful.
I wonder if this outfit includes a rigidity group in DS and if yes, could it be a reason for DSON failure.
its driving me bonkers, i've tried everything i can think of and tried it several times just to make sure
anyone else having this problem?
No, sorry -_- But I don't use Poser
I just encounter this error today. I auto fitted a Victoria 4 shirt to Genesis. I saved the item as a Support Asset > Figure/Prop Asset to a folder under "My Library". I created the poser companion files and when I loaded it into Poser got that exact error. I uninstalled and reinstalled DSON, but it did not help.
I looked at the files DSON created. I noticed it created a cr2 file, but not an obj file.
I think I found a workaround.
After I auto fitted the shirt, I saved the file to a folder under the "Poser Content" folder. When I saved this time, the file name did not have spaces. Also, I set the author, product name, and product item name. Then I created the poser companion files from the new file from the "Poser Content" folder. I loaded this one into Poser and it seem to work properly.
I hope this helps your situation.
