Looking for Iray beams and tents
in The Commons
Hi all!
I'm looking for some Iray compatible tents (acient or ethnic looking) and Iray compatible wooden posts or beams. They can be smooth or rough, lumber or logs might work too.
Do any of you know any packages that contain this?
Thanks a lot,
Me
https://www.daz3d.com/knights-pavilion
This was the first that came to my mind, not sure if it is what you are looking for though - https://www.daz3d.com/de-nomadic-tentz
Thanks! looks great! Looks like tents are covered! Do you know of any sets that contain individual wooden beams, logs, lumbers or posts?
Thanks a lot,
Me
Nothing I can think of that would be what you need, there is a few products that contains logs for campfires and such. So perhaps you could take a log from one of those and resize, before putting a wooden shader on it? Though I suspect it may be easier to make a cylinder primitive in the size of a pole (might need some resizing to get as you want. You find it under Create - Create New Primitive - pick cylinder in the drop down), than use a wooden shader on it.
Some shaders which has wood in them, there is many more but these might give an idea of what is available to get :) https://www.daz3d.com/architectural-iray-shaders https://www.daz3d.com/fsl-weathered-shaders-for-iray
